"Pete's Toon Factory" The End
    Hi added some ID marking to bunker base, added turret base colour.
    [ATTACH=CONFIG]n[/ATTACH]
    Made trans bolt strip, cut slot and fitted for the "Wolverine".
    Removed rear engine doors, added exhaust pipes, tow bracket and hex nuts/ washer to the ends of idler axles.
    Not much today sorry about that.
    Pete.
      this what you call a tank bunker.
      Pete.
        Hi sorry It's me again, I've got a bit more done just hope it come's out ok still having trouble so no background story.
        Got the most of the hull built and all the suspention done.
        [ATTACH]344791[/ATTACH]
        [ATTACH]344792[/ATTACH]
        [ATTACH]344793[/ATTACH]
        [ATTACH]344794[/ATTACH]
        Thank you for looking in.
        Pete.
          Excellent finish on the last two :smiling3: .
          • scottie3158
            • 14211
            • Holbeach
            #95
            Pete,
            Great work on the hull looking great.
              Hi I'm also building a Sherman memorial turret Bunker , Bastogne-Belgium. On all the major roads into Bastogne, Sherman turrets of different types mark the places where the German advance to capture the surrounded city was stopped.
              [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
              [ATTACH]344799[/ATTACH]
              [ATTACH]344800[/ATTACH]I
              [ATTACH]344801[/ATTACH]
              Thank you for loking in .
              Pete.
              • SimonT
                • 2824
                #97
                Pete - the Matilda looks much better without the golf tee
                Wasn't sure if that 'bunker' was real or just someone messing about with Photoshop again, but it appears to be real, the Lebanon Peace Monument. There is also one full of cars.
                Looks like a T55 on the bottom with an Israeli M50 above it and possibly a Saladin A/C above that
                Just looked it up on wiki and apparently there are 78 tanks/armoured cars in there along with 5000tons of concrete - would certainly make a very different model
                  Pete,
                  As always, they hit the mark, well done.
                  Cheers, Mike.
                    Hi calling the Panther Ostwallturm finished.
                    [ATTACH]345245[/ATTACH]
                    [ATTACH]345246[/ATTACH]
                    [ATTACH]345247[/ATTACH]
                    The Sherman memorial turret Bunker Bastogne.
                    Started on the base, made the wall using plaster and carved the bricks in, painted / weathered and added some flora.
                    [ATTACH]345248[/ATTACH]
                    [ATTACH]345249[/ATTACH]
                    [ATTACH]345250[/ATTACH]
                    Pete.
                    • scottie3158
                      • 14211
                      • Holbeach
                      #100
                      Pete,
                      You never disappoint great work on the panther turret and the ground work for the Sherman looks spot on.
                        Pete,
                        Hi Paul I keep trying my best, I'll get there one day :smiling4:.
                        Pete.
                          Hi have managed to finish the Sherman memorial turret Bunker Bastogne.
                          So I have five new one's to show in December at a model show in London just ten more to do.
                          I hope JR dosn't see the state of this garden.
                          [ATTACH]345320[/ATTACH]
                          [ATTACH]345321[/ATTACH]
                          [ATTACH]345322[/ATTACH]
                          [ATTACH]345323[/ATTACH]
                          [ATTACH]345324[/ATTACH]
                          [ATTACH]345325[/ATTACH]
                          Hope you like it.
                          Pete.
                          • JR
                            • May 2015
                            • 18273
                            #103
                            Originally posted by Pete Low
                            Hi John this might answer your question.
                            The concrete sub-structure was a standard construction (Regelbau 687) built by the Organisation Todt (OT). It required some 175 m3 of concrete and approximately 10 tons of steel to reinforce the structure. When finished the bunker was slightly higher than the surrounding ground. This was to enable the construction of an angled apron of concrete, which was designed to prevent enemy fire from penetrating the bunker and to prevent blast damage to the loose soil around the turret when the gun fired.
                            The bunker itself had three rooms. The room directly below the turret housed a motor that operated the hydraulic rotation mechanism in the turret. Using this the turret could be traversed at six degrees per second. The motor also powered a compressor, which provided compressed air to flush out the barrel. Behind this room was an ammunition storage room which was capable of storing 450 rounds of 75 mm ammunition. The room below the turret that housed the motor was linked by several wooden steps to an ante-room. This was home to a generator and a battery which provided power for lighting, to operate the turret fan and for the electrical discharge. It also doubled as the crews living quarters and was fitted with a stove, but no beds. The smoke from the stove, together with the exhaust from the motor, was vented outside by means of a chimney. A door linked this room to a staggered entrance at the rear of the installation that led to a communication trench.
                            Pete.
                            Thanks Pete, it does indeed .
                            • JR
                              • May 2015
                              • 18273
                              #104
                              Pete, a great looking model, and the gardens not bad either . :smiling:
                                Hi John If your happy with it that's good enough for me :thumb2:.
                                Pete.
