BA-3 Russian armoured car 1/35 scale
    John,
    Smashing, love how the groundwork has come together, now looking forward to the completed finish.
    Mike.
    p.s. did you say a while ago you had run out of ply bases?
    • Mini Me
      • Jun 2018
      • 10711
      #17
      Yes Andy, JR plays with matches quite often, that is until Matron catches him and it's a dose of meds and back to bed for the errant lad. Cheers, Rick H.
        Originally posted by MikeC
        John,
        Mike.
        Thanks Mike, don't think I did, still have a few 18 mm boards under the spray booth . But did have a change of bases recently with the picture frames .
        Rick, now you know that's not true when you say ," quite often " it depends on what you mean by often .
        I've only had two fires in a year, the third one was nothing to do with me , that just happened ! :upside::upside::upside:
        • Mini Me
          • Jun 2018
          • 10711
          #19
          What about Roarke's drift???? I know 570 can't prove it but that had your signature as well!!
          Cheers, Rick H.
            Cheers, Rick H.
            Ok three then Rick :smiling:
              After a day of prolonged rain the best place to be was either asleep or in the cave.
              I'd previously applied a gloss varnish to the model and all the small parts. These had been sitting drying over night.
              Even with a gloss coat the oil wash didn't want to flow, suspect the mix was to rich and not enough medium. Soon I had three separate plastic tops with different mixed in.
              The first oil wash can dry, then I can blend it in, as I start in the rust colours.
              I wanted the black around he turret to look like smoke deposits.
ID:	1096662Click image for larger version
ID:	1096665Click image for larger version
              Nice group of Hornets, this time I've used old sprue, dab of CA, done.
              I like the wheel assembly with half the shaft :nerd:.
              Comments please, have I got it rightso far ?
              Still a lot of work to do with the oils.
              Then the figures :nerd::nerd::tongue-out::smiling:
              John .
                • 15819
                Hi John
                That is looking very good. You have a knack for making groundwork. Useful tip with the IPA. Armoured car looks well wrecked and all the scattered bits will really tell the story.
                Good for you buying the Hornet Heads from Historex. I reckon those heads are some of the most commonly copied things out there.
                  Looking amazing to my untrained eyes.
                    Originally posted by Jim R
                    Hi John
                    Thanks Jim. As you know I love the ground work part a lot. That IPA is a mix at 30%, I've tried a spray bottle, that's ok, but tends to blow loose stuff away. The best method is with a pipette, just a drop here and there, it spreads so quickly.
                    Having read an article by Rodger Saunders I feel very strongly about this.
                    Here is the article by him, no doubt you have seen it before but others may have not .
                    I think it is well worth posting again .
                    John .
                    Piracy
                    Here are examples of just a few pirated Hornet products:
                    Hornet HBH02, 01, 05
                    Various Hornet heads
                    Hornet GH21, copied in resin
                    All copyright in Hornet products rests with me, Roger Saunders, and I do not authorize reproduction by any other manufacturer. After all, other companies are in competition with me! Nevertheless, unauthorized copying is widespread, ranging from companies who use Hornet heads and hands on commercial figures to blatant passing off of copied models as the real thing
                    Illegal commercial copying is a persistent and real problem, and many companies suffer from it. I have read several discussions about this on various forums, and I would like to give my views on some of the points made.
                    How can I be certain that I am buying the genuine thing when I see it on the internet?
                    If the seller does not state that the item is โ€˜Hornetโ€™ then it almost certainly is not, even if the picture suggests that it is. The copyists often use a picture of the original manufacturerโ€™s product, instead of the copy that they are really selling, and they frequently download images from the hornetandwolf website. Be suspicious of low prices. Specify that the item must be genuine and give the seller a lot of bad feedback if it turns out not to be. Donโ€™t be fooled by lots of stars on their satisfaction rating.
                    How do you know if an item is a copy?
                    It will almost certainly lack Hornet packaging. The pirates often use a resin of a different colour and texture. Detail will not be as sharp as you would expect, and the proportions tend to be distorted. The pouring blocks of individual Hornet heads all have reference codes โ€“ the pirates usually take these away. The copied sets of heads may be on a single slug to save costs.
                    Prices for the genuine articles are far too high. If manufacturers reduced prices the motive for copying would disappear.
                    Unfortunately, if I did this my motive for producing them would also disappear.
                    If prices were slashed sales would increase dramatically and so Hornet would sell more to compensate for the lower price.
                    The market for these items is worldwide but small. The manufacturing process will only work for quite small production runs. Real economy of scale is impossible.
                    If a pirate company can sell copies at around $8 why canโ€™t you? They have to use the same materials and methods.
                    The pirate company can simply take a model that represents weeks of painstaking work and pop it into a mould. As a general rule they are also based in a country that is far less expensive to live in, and run a business in, than mine. Often they do not sell via merchants, and so do not have to build a trade discount into the price.
                    So why not sell direct, cut out the retailers and distributors, and lower the price?
                    Without the retailers and distributors my sales would collapse. I am only one man, and my main function is producing models rather than marketing worldwide.
                    These copyists are doing a service to the hobby by making the models available to people who could not afford them otherwise.
                    Arguably true in the short term. But in the long run they are harming the hobby. Why should originators like me labour to make new products that someone else promptly steals?
                    Cut to the chase. Why should the customer not buy wherever he finds the best deal?
                    Buyer, beware! When an item is copied in commercial quantities it has probably been remoulded at least two times. Each time it distorts, usually shrinks, and detail is lost.
                    At the prices you charge you must be making a lot of money. A few pirates arenโ€™t going to do you much harm!
                    I love this one! Despite the tremendous publicity Hornet products receive, actual sales are modest. Believe me, my income is not likely to provoke gasps of envy, and it is declining year by year. I think pirating is doing me a lot of harm. Copying is done on a well organized commercial scale by a lot of people. An offender in China claimed to hold more stock than I do myself! And his website described the knocked-off heads as being โ€˜top sellersโ€™!
                    So why donโ€™t you do something to stop the pirates?
                    As the creator I hold all copyright to these models. But practical measures are difficult, and there are always yet more copyists- many of which are beyond UK, EU or US jurisdiction.
                    Why not name and shame the baddies on your website?
                    Human nature being what it is, it would probably give them more trade!
                    Most of these guys use PayPal to get paid. Complain to PayPal!
                    I tried once. My tears shorted out the keyboard after a few hours. eBay is better, but you have to find out each and every time an item appears, and formally complain afresh before the sale ends. It then tends to appear again after a short interval and you have to start again. Discussion with either of these organizations seems almost impossible.
                    So what is the answer?
                    At present there doesnโ€™t seem to be one. I suppose that if hundreds of enraged customers complained to PayPal and eBay (scroll down and find โ€˜report itemโ€™ to the left of the posting) each time knocked off models appeared they might do something. Itโ€™s not very likely though. The more folk that can resist the temptation to buy copied stuff the longer people like me can carry on, but the omens are not good.
                    NB. All readers are welcome to copy and pass on the above as they wish. By all means use it in discussion forums whenever the topic comes up!
                    • grumpa
                      • Jan 2015
                      • 6142
                      #25
                      Love it so far John, if all else fails give it a good bashing I always say.
                      Cheers Jim.
                      • Steve Jones
                        • 6615
                        #26
                        Wonderful work mate. You really are good at these wrecks. Have you and Jim been swapping notes?? LOL
                          Agree with the others John - wonderfully realistic work.
                          As for the piracy, it always pays to go to reputable dealers.
                          • Steve Jones
                            • 6615
                            #28
                            I'm new to this world of piracy in models. I can spot the signs with figures but how do you spot an AFV kit? Does it come in a fraudulent box like a pirate DVD?? Do fraudulent AFV kits actually exist??
                            Apologies for hijacking your post mate
                            • Andy Belsey
                              • 887
                              #29
                              I was admiring your work on the burnt out vehicle thinking of the poor bu**ers, who probably didn't get out of it and then I scrolled down to all your trophy heads! The all this talk about pirates....
                              By the way, I fully support the fight against piracy. Those who try to scratch a living from our hobby could do without parasites creaming off the little they do get. None of us should be tempted to their cheap prices but buy from genuine sellers like John.
                              Andy
                              • scottie3158
                                • 14256
                                • Holbeach
                                #30
                                Looking good John, as the others have said you have the knack for this.
