With the interim Ki-43 finished and the temperatures back to a tolerable level in my hobby room, I finally managed to do some more work on the M70A2. It doesn’t look like much, but quite a lot of staring at photos and other thought had to go into parts of it:
[ATTACH]355066[/ATTACH]
These are the main bits for the remote-control AA turret. As shown earlier, I’ll replace the cannon by an M85 machine gun, and on the left is the basis of the mounting for that. I built a cradle from plastic strip, after sawing away parts of the trunnions (the big cylindrical things), because Dragon had got them somewhat wrong: on the real thing, only the top is as wide as the model portrays it, while the bottom is mostly open. I also added a bit of detail into the left-hand one, which I think is a device to measure the elevation and feed it back to the fire control system. This whole mounting still needs quite a lot of additions, mainly an ammo bin underneath, probably also a spent casings bin (as I don’t think they’d want those to just drop into the turret), and ammo feed chutes, plus the elevation motor and some cabling. Dragon omitted all of this, despite it being very visible
The other bit is the turret, with internal detailing that Dragon similarly omitted entirely. There are two small bins of some kind — their purpose escapes me — plus lifting hooks and a traverse motor. I also closed the opening for the 20 mm barrel with a piece of plastic card that I then shaped to conform to the rest of the turret before cutting a much smaller slot for the M85’s barrel.
Getting there, slowly but surely
