Pete's Stummel
  • stillp
    • 8096
    • Pete
    • Rugby
    #31
    After a busy few days with 1:1 stuff, I've done a bit more. I don't think I'll ever get the hang of airbrushing small mottles - whatever I do I seem to get spidering and splatter. :disappointed:
ID:	1099747Click image for larger version
ID:	1099748Click image for larger version
ID:	1099749Click image for larger version
    Oh well, it'll look OK from a distance, if you squint a bit.
    Added a few more sticky-out bits, and the second fire extinguisher that I'd forgotten:
    A bit more hairy stick work needed and then I can put the wheels on.
    • scottie3158
      • 14211
      • Holbeach
      #32
      Pete,
      Looks good mate the odd blemish can be lost with weathering and washes.
        Pete,
        Get a hole punch and randomly punch holes around a pre drawn pattern on thin card, I use the card that comes with Eduard etch sets. You cab then euther hold the card or double up some masking tape to hold the card away from the model - gives you a soft edge.
        Remember these vehicles were painted in the field as well as the factory, and the ordinary squaddie was not Picaso...
        Cheers, Mike.
        • BattleshipBob
          • 6803
          • Bob
          • Cardiff
          #34
          What a good idea Mike, wonder if that can used for the He 219's camo??
          • stillp
            • 8096
            • Pete
            • Rugby
            #35
            Originally posted by MikeC
            Pete,
            Cheers, Mike.
            Thanks Mike, I'll try that.
            • JR
              • May 2015
              • 18273
              #36
              Handy Tip No 126 from Mike.
              That should do it Pete if your still not happy, I'm with Paul on this, once you have a bit off weathering mud etc it will look perfect .
              • stillp
                • 8096
                • Pete
                • Rugby
                #37
                Well, decals are on, and I've started getting it dirty:
ID:	1100237Click image for larger version
ID:	1100238Click image for larger version
                • stillp
                  • 8096
                  • Pete
                  • Rugby
                  #38
                  "Stummel, Stummel, spoil and struggle", as Shakespeare almost said! Now finished.
                  I'll put up a 'completed' thread in a few minutes.
                  • scottie3158
                    • 14211
                    • Holbeach
                    #39
                    Pete,
                    That is a great result and hard to believe it's not a bigger scale.
                    • stillp
                      • 8096
                      • Pete
                      • Rugby
                      #40
                      Thanks Paul!
                      • Steve Jones
                        • 6615
                        #41
                        Great work Peter. I have enjoyed seeing this one come together. I will pop over and have a look at the finished article. Well done sir :thumb2:
