Top work as always Neo. Now I used to do weld seams in the same way. However I found the stuff would not stay stuck to the surface and would come off when I made the seam detail or when it had set and it just fell off. Do you have this problem?. I used to use milliput.
Mannschaftstransportwagen Magirus ARW
I let it dry a little (5-7 minutes) and it doesn't get so sticky.Comment
You mean: “Fortunately I didn't use Milliput ever.”Seriously, almost any other brand of epoxy putty is easier to use than Milliput, in my experience.
All epoxy putties I know harden in two stages: after you mix it, it sticks to everything, then it stays soft but doesn’t stick anymore, and then sets hard. One of the mains differences between different makes is how long it takes to go through those steps.Comment
You mean: “Fortunately I didn't use Milliput ever.” :smiling3: Seriously, almost any other brand of epoxy putty is easier to use than Milliput, in my experience.
It is quite hard to get Milliput for me. So after your words I think I am lucky twice :smiling5:
Some fresh information. Welding is very boring process. I have started it. It seems to me I will need all next week to complete this work. Or maybe more.
By the way. Good modeller from Armorama has mentioned that model hull has diffirent angles and forms . You can see it on comparasion photos.
[ATTACH]353434[/ATTACH]
[ATTACH]353435[/ATTACH]
