Mannschaftstransportwagen Magirus ARW
  • scottie3158
    • 14256
    • Holbeach
    #46
    Great work on the weld beads
    • Neo
      • May 2018
      • 526
      #47
      Greeting! I am on a half way with welds. Bottom of arches , turret box ,front and rear parts are ready. Now I have to weld sides. I have begun and I am satisfied with the results. It was long way to do it. Hard work with plastic , welds , special grooves for welds. Sorry for bad photos. I will make good ones when welds be ready.
      • scottie3158
        • 14256
        • Holbeach
        #48
        Excellent work on the welds mate. The time taken was well worth the effort.
        • Neo
          • May 2018
          • 526
          #49
          Thank you,Scottie! This is very boring process but I like the result
            Nothing wrong with those photos — they clearly show your additions to the model, which looks very well done too.
              • 15819
              Hi Artyom
              Excellent, neat welds done nicely to scale.
              • Neo
                • May 2018
                • 526
                #52
                Thank you! But in future I will do better photos.My second camera has been repaired.
                • Neo
                  • May 2018
                  • 526
                  #53
                  Originally posted by Jim R
                  Hi Artyom
                  Hello Jim and thank you! It wasn't easy but I satisfied. At last
                  • Neo
                    • May 2018
                    • 526
                    #54
                    Hello friends! The work with hull welding has come to an end. I satisfied with the result.
                    [ATTACH]355057[/ATTACH]
                    [ATTACH]355018[/ATTACH]
                    [ATTACH]355019[/ATTACH]
                    [ATTACH]355020[/ATTACH]
                    Next stage - wheels. They are terrible! Every wheels consist of two parts. And it is not a funny story to put them together because parts curves. I have seen the reception on Gleb Vasilliev's Magirus. He has put on some plastic between two parts. I've decided to do the same.
                    And I see this insert in the center of the wheel on photos. Take a look.
                    [ATTACH]355021[/ATTACH]
                    I still need to fill the gaps by putty.
                    [ATTACH]355022[/ATTACH]
                    [ATTACH]355023[/ATTACH]
                    [ATTACH]355024[/ATTACH]
                    • scottie3158
                      • 14256
                      • Holbeach
                      #55
                      Great work.
                      • Neo
                        • May 2018
                        • 526
                        #56
                        Great work.
                        Thanks,Scottie!
                        • Steve Jones
                          • 6615
                          #57
                          Glad you have finished the "chore" of doing the welds. Well worth the hard work. Nice attention to detail on the wheels
                          • Neo
                            • May 2018
                            • 526
                            #58
                            Hello,Steve! Thank you! Sorry. My answers are bit too late. Very busy at work. But when I have some free time I continue my work.
                            Exhaust pipe and it's fixators. Resin,putty,brass,copper. I have drilled 1,5 mm wire to make a pipe. That was crazy :smiling5:
                              Are you sure you’re working 1:35 scale and not, oh, 1:8 or so?
                              • Neo
                                • May 2018
                                • 526
                                #60
                                Are you sure you’re working 1:35 scale and not, oh, 1:8 or so? :smiling3:
                                I afraid yes :smiling5: I think somethingin 1:8 I can do for years
