Pete's BAE Warrior
  • stillp
    • 8093
    • Pete
    • Rugby
    Pete's BAE Warrior
    Something a little larger than the Stummel, to give my aged eyes a rest! Airfix 1/48 BAE Warrior, the op Herrick version. Bought at the recent Coventry IPMS show for a tenner.
ID:	1100338Click image for larger version
    Rather a lot of plastic - 257 parts. Should keep me busy for a while.
    Off to wash the sprues now.
    • 15696
    Hi Pete
    Lots of parts for a 1/48 kit. That slat armour will be fun to do :rolling:
    • scottie3158
      • 14201
      • Holbeach
      Hi Pete,
      Chair pulled up.
      • Mickc1440
        • 4779
        Evening Pete, this was the only one I haven't built in their gulf war vehicles, I'll join the growing mob
        • stillp
          • 8093
          • Pete
          • Rugby
          Welcome Jim, Paul and Mick, plenty of room! You'll have to bring your own biccies though!
            I'm in. That's a lot of plastic for a tenner!
            • stillp
              • 8093
              • Pete
              • Rugby
              Moulding seems pretty good - not much flash, but the little bit there is, is of course on really thin parts that'll be tricky to clean up.
              With 'bargain' second hand kits, there's always a risk of missing or broken parts. The sprues were in a sealed bag, but this part was loose:
              Should be easy enough to identify, when the time comes to fit it!
              One part is broken:
              That might be more of a problem.
              I was going to post that I'd found the first poor fit already, as the bit at the bottom of the seat backrest didn't fit into the hole at the back of the seat base... then I realised I'd sanded the locating pin off thinking it was part of the sprue gate! :rolling: There seems to be quite a detailed interior, none of which will be visible when the model is completed. I might be able to leave a hatch open - anyone know what colours the interior should be?
              I've labelled the sprues to make life a little easier:
              I knew those Post-it file tabs would be useful some day!
              Thanks for watching.
              • stillp
                • 8093
                • Pete
                • Rugby
                I see you think like I do Andy!
                • Steve Jones
                  • 6615
                  That's a lot of kit for a tenner! Looking forward to seeing this one coming together . Good luck
                    [ATTACH=CONFIG]n1100357[/ATTACH]
                    Hint: it goes onto the front of the turret and the gun barrel sticks out of the front of it
                    That kind of surprises me. Academy’s 1:35 scale Warrior doesn’t have that feature.
                    The hatches in the rear deck should afford a good view of the interior, especially if you also leave open the big door in the hull rear.
                    Not off the top of my head, but I suspect it’s pale green.
                    A bit of searching turns up this photo:
                    [ATTACH]350959[/ATTACH]
                    Found on a site where someone else also built this kit. It looks like the interior is a medium shade of military green, with bare metal anti skid plates on the floor, a lighter (grey?) colour behind the seat backs, and olive drab and black for various major parts.
                    • prichrd1
                      • 691
                      • Conwy
                      Pete,
                      Loads of piccies & ideas here:-
                      Warrior
                      HTH,
                      Paul.
                      :smiling3:
                      • stillp
                        • 8093
                        • Pete
                        • Rugby
                        Thanks Jakko.
                        Originally posted by Jakko
                        Hint: it goes onto the front of the turret and the gun barrel sticks out of the front of it :smiling3:
                        Yes, that's why I said It'd be easy to identify!
                        What was I thinking? Of course I can leave some hatches open! The driver has a seat but no controls or instruments, so I'll leave the driver's hatch closed, but the rear doors and possibly the turret hatches will be open.
                        I found that same photo after I'd posted the question. I think the floor plates are painted green but the paint has worn off on the chequering. Airfix suggest khaki drab for the seat frames and floor, dark green for the seats, US Ghost Grey for the rest of the interior, Desert Tan for the main exterior colour. There doesn't seem to be any equivalent to the latter, so I might have to try airbrushing Humbrol acrylic - wish me luck!
                        Originally posted by prichrd1
                        Pete,
                        Warrior
                        HTH,
                        Paul.
                        :smiling3:
                        Great link, some useful stuff there, thanks Paul.
                        • JR
                          • May 2015
                          • 18273
                          I shall join the crowd , bit modern for me so will sit at the back and watch .
                          • stillp
                            • 8093
                            • Pete
                            • Rugby
                            Well the Humbrol Desert Tan is discontinued, so I'll be using Tamiya paints. Had to buy a couple that I was missing, but since I bought them it's been too hot to paint, and I can't do much else until I get the paint on the interior.
                            • stillp
                              • 8093
                              • Pete
                              • Rugby
                              As usual, I didn't plan ahead - started sticking the seats in before I realised I should have painted the hull interior first, then used the wrong colours! So, after a bit of brush painting, this is where I've got to:
                              I dry brushed some aluminium on the floor, then splashed some washes about while access is still good. I'll be leaving the fron hatches closed, as Airfix give the driver a seat but no controls or instruments.
                              I'm not completely happy with the fit of the back panel, but it'll have to do.
                              Next is the turret basket.
