Pete's BAE Warrior
  • stillp
    • 8097
    • Pete
    • Rugby
    #61
    But is it really authentic Laurie, being so much overscale? I'd have done the same as you, if I'd been doing a Herrick dio, on the basis that they had bar armour in Afghanistan, so it has to be on the model, even if crudely represented.
      Probably more authentic as with out the Armour totally un-authentic.
      Just a total screw up by Airfix on a great model. great to build. As are
      all the Herrick models.
      Look forward to seeing yours "sans" armour. Nice discussion Pete
      • stillp
        • 8097
        • Pete
        • Rugby
        #63
        Well, armour or not, it needs tracks:
        Done!
        As are those pesky turret hatches:
        Now there are lots of little bits to add on the hull, some of which are built up as subassemblies:
        While some just need gluing on.
        It's good to make some progress!
        I can always add the bar armour later if I change my mind... just wondering if anyone makes grating for ships or model railways, that would be better than the Airfix parts.
          Nice work Pete.
          • Steve Jones
            • 6615
            #65
            Comin on well Pete. Great work on the tracks
            • stillp
              • 8097
              • Pete
              • Rugby
              #66
              Thanks Steve. Been a bit distracted by other things for a few days but I'll have to get on with this soon.
              • scottie3158
                • 14220
                • Holbeach
                #67
                Pete,
                This is looking good, coming together very nicely.
                • stillp
                  • 8097
                  • Pete
                  • Rugby
                  #68
                  Well, I haven't found any gratings that would be suitable for the bar armour. I did have a play with some brass shim, and I think I could make something more to scale, but it'd take me well into next year at the rate I work! I think I might use the overscale Airfix armour after all.
                  Anyway, I've been plodding on - I'm not good at planning which parts to paint before assembly, so it's been a matter of painting a bit, then gluing a bit...
                  Here's some progress photos:
ID:	1104848Click image for larger version
ID:	1104849Click image for larger version
                  Next up are the front lights and their protective guards, and the tools, which will be painted before fitting. I've been brush painting, but I think it's going to need a final coat from the airbrush, as the paint (Tamiya XF-59 Desert Yellow) seems to dry a slightly different colour depending on how thickly it goes on.
                  Thanks for looking in,
                  • stillp
                    • 8097
                    • Pete
                    • Rugby
                    #69
                    A few more tiny steps...
                    I thought these guards would be a paint to clean up when I saw the attachment points, but they weren't too bad.
ID:	1105167Click image for larger version
                    I guess I should have filled those sink holes in the headlamps before fitting the guards though!
                    I've taken the driver's hatch off as I had it open too far.
                    • scottie3158
                      • 14220
                      • Holbeach
                      #70
                      Pete,
                      Looking good mate, to fill the holes in the lights stand the vehicle up the place a drop of PVA on each of the lenses this should fill the hole and leave them slightly domed.
                      • stillp
                        • 8097
                        • Pete
                        • Rugby
                        #71
                        Good idea, thanks Scottie!
                        • Steve Jones
                          • 6615
                          #72
                          Nice work Pete. Sink marks are the bane of my life at the moment on the Bison build. Looks like some good advice from Scottie
                          • stillp
                            • 8097
                            • Pete
                            • Rugby
                            #73
                            Seems to have worked too!
                            More later, I'm waiting for a boiler repairman to arrive, so can't really start anything or the doorbell will ring at the worst possible moment!
                              • 15737
                              Hi Peter
                              Glad I'm not the only one. I can think about it until I get a headache and I still get it wrong :anguished:
                              Warrior is looking good and that was a clever idea from Scottie - I'll make a note of that :thumb2:
                              I too have noticed that some paints do look a different colour when brush painted from airbrushing. Makes touching up a pain.
                              • JR
                                • May 2015
                                • 18273
                                #75
                                Coming on Pete.
                                I'm another that forgets to paint something at the right time or when they are painted, removing the other paint to fit the new part I end up messing it all up .
