Morning all,
this is one that I started way back in 2016 on the site that shall not be named :surprised:
I have gradually been chipping away at it every now and then and it is now almost ready to hit the spray booth
As usual it needed a little work to improve things
exhaust silencers wrapped with pewter to form proper lipped ends, new tailpipes from aluminium wire drilled out
catches added to rear hatches
cover added to spare wheel - this has since been added to with Duro to give a sagged effect
the wishy washy details removed from the stowage cupboards and replaced with Historex buckles
Pewter brackets added, wire step
shovel got some mountings
the worst part of the kit is the turret - for some reason ICM chose to mould it with an odd semi solid inside
that was all carefully pared away to just leave the angled armour plates. A new 'floor' edging and turret ring were created from plastic card
the new bits from underneath
as a result of the poor turret moulding the gun mount suffered from lack of detail and over simplification so the kit parts were discarded and a new mount created
the basic mount being tested with the corrected turret
the kit comes with a small etch fret that provides the rear half of the upper deck and the turret anti grenade screens
turret internals progressing
and a bit further......
