Meng 1/35 Whippet
    Not much of an update as it's been pretty manic at work. They've decided to put me through my Fire Marshall training again and I'm currently part way through a 3 day First Aid course. It's leaving me very little free time but at least I should be prepared for most scenarios!
    I spent a whole night just deciding on colours, then mixing them up from the limited palette I have. I'm going for something along the lines of the picture simon posted of a captured version, but just for a laugh I've added a red-brown too, so that's 4 colours in to
    They'll be less intense on the model of course but all are mixed from Mr Color. The grey is a lightened version of their RLM66, which will also be further lightened for highlights.
    Yellow is their C-39 Dark Yellow
    Green is a mixture of 4B0 Russian Green and C-12 Olive Drab
    Red / Brown is a mixture of those two colours, roughly 50/50, C-3 & C-517
    As I say, the picture shows pretty intense blobs (over the top of the grey primer) but they were hard to photograph and look more muted on the tank. I'll also try and add highlights and shadows by mixing yet more versions. Sounds good in theory but we'll see how it goes in practice :smiling5:
    So far I've done an overall coat in the grey and have started adding patches of yellow. Slowly does it :smiling3:
    • scottie3158
      • 14220
      • Holbeach
      #47
      Andy,
      That looks pretty good to me mate.
        Managed to get some painting done between everything else real life is throwing at me right now. The colours look a bit bright, especially the yellow, but the lighting and gloss coat aren't helping that. Should tone down nicely with washes, a coat of matt varnish and a bit of weathering.
        Still a long way to go but the basic foundations are laid at least.
        • scottie3158
          • 14220
          • Holbeach
          #49
          That looks excellent and once toned down that will look perfect.
            Thanks Paul. Can't seem to get the lighting right in the shed, either for working or taking pictures. Will have to look into that when I get around to re-jigging the place.
            • Allen Dewire
              • 4741
              • Allen
              • Bamberg
              #51
              Evening Scratchy,
              I am way too late to the party as usual. Sorry for that Andy...When I saw the title, at first I thought someone was building a model of a racing dog!!! Boy, was I wrong about that. Top work so far and great forethought about saving the little pieces for last so they won't get broken off.
              Once again, super scratched additions and a top notch spray job with the hissy stick. I will try to pay more attention from now on. Hope your work eases up and gives you more play time at the bench....
              Allen
                Hey Allen, great to have you along. Not one of our four legged friends I'm afraid but glad you like it so far.
                Slowly working my way through the track links behind the scenes too. Doing a batch at a time seems to work for me as I have the attention span of a 3 year old!
                  The first couple of photos make it look like you painted the intake grilles a bare metal colour, but it turns out that’s just the lighting Looking very good, though.
                  Oh, one thing I just noticed: the mufflers on the real thing were wrapped in asbestos rope between the attachment rings. It should replicate nicely if you just wrap white thread around it.
                    I decided not to go with the wrapping after a bit of research. I left the exhausts off initially while I considered it as that would have been the best time to do it, but after reading a few comments and seeing a few images of an extra metal cover over the asbestos heat wrap layer, I figured that look would be easier, even though it appears it was often missing.
                    • Si Benson
                      • 3572
                      #55
                      Hi Andy,
                      Not looked in for a while and you’ve motored along! That paint will look fabulous once the weathering starts:thumb2:
                      • SimonT
                        • 2824
                        #56
                        Paint looks good Andy
                        Good call on the exhaust - there are plenty of photos showing with and without the covers
                          Thanks Si & Simon.
                          I managed to over-thin a couple of the colours so made life harder than it needed to be. First go with the new airbrush and it behaves very differently to the cheap one I've been using up to now, flowing much better without needing the paint to be so runny, but it's all part of the learning process.
                            • 15737
                            Hi Andy
                            Boxes look good. Paint job is fine and as you say washes will tone down the brightness and pull it all together. You've made great progress with this.
                              Thanks Jim.
                              The yellow is my main concern right now but isn't quite so bad in person. It's the same dark Sandy yellow I used on my BTR80 but looks so much brighter here!
                              If the washes don't tone it down enough I'll go over it with a tinted clear, which I think is known as a filter in modelling circles.
                                Tracks on for a test fit. They only had a quick coat of steel on the sprue so will need further work, but at least the hidden parts are covered in something.
                                Most of them clipped together pretty well but I think I'll be gluing them when the time comes as the odd weak joint keeps popping. I've substituted the really loose fitting ones already, and with a whole sprue full of spares not touched yet I've got plenty to go at, but still I think long term gluing them might be prudent.
                                I've also fitted the guns and somehow they still move which is a bonus. Must have done something right.
                                Tried a light filter coat of dark brown over the lower half to tone down the colours too. It's starting to look better already but the varnish I used to seal the decals is still a bit soft so haven't touched the main body yet. First time using this particular varnish and went a bit heavy I think.
