SimonT - Hobbyboss 1/35 Russian T-18 Light Tank
  • JR
    • May 2015
    • 18273
    #166
    Originally posted by minitnkr
    I used plywood profiles, old nylon window screen, & wallpaper paste soaked craft paper for the base & drywall finishing plaster for stone outcroppings on my early RR layouts. I still use the screen & topping compound for crowned roadways today. Weight has not been an issue w/this method nor has cracking/shrinking, even when left in an unheated garage for several years. The last few dios have used packing foam & foam board as the base w/topping compound as a finish. Not thrilled w/foam board. Prolly my fault. PaulE
    Paul there seem to be two types, polystyrene or polyurethane. The later is the best for modelling, easier to peel the paper off and takes impressions better as it is a close cell construction.
    • minitnkr
      Charter Rabble member
      • 7538
      • Dayton, OH USA
      #167
      Can you tell me how to visually discriminate between the two? PaulE
      • SimonT
        • 2824
        #168
        For those of you that like watching paint dry, here is the next best thing
        base is drying nicely
        • JR
          • May 2015
          • 18273
          #169
          Am I sad or what but that is great !:nerd:
          • SimonT
            • 2824
            #170
            I think we are on to a winner with this stuff John
            • SimonT
              • 2824
              #171
              Definite success with the Sculptamold - dried nice and solid with no shrinkage
              Covered the stream bed with Javis sand Monday night
              When I got home from work yesterday I stuck some pre-made tufts to the top of the base edges to form low bushes then mixed up some AK rough earth paste with Russian earth, brown and black pigments. This was then knifed it on to the base.
              Used a paintbrush to spread the paste around and cover the slope and upper areas being careful to push it around the tufty bushes and not over them
              Then I plonked the T18 into the paste to get a good sit into the ground
              Sprinkled the rest of the paste with Javis field scatter and dabbed it with a sponge to make sure some of it stays put
              As the paste dried out I worked some rough areas into the track using an AK brass toothpick
              I found the missing track link the other day so glued it to a length of sprue and pushed that into the ground in an attempt to make some track impressions - didn't work too well as it just got clogged with paste
ID:	1109421Click image for larger version
ID:	1109422Click image for larger version
              • Steve Jones
                • 6615
                #172
                Well the base has certainly come out a treat. Looks like you are onto a winner there. The tank certainly looks the part. Great stuff all round sir.
                  Base is looking great, might have to look into that sculptamold myself now that I've started doing a few.
                    • 15698
                    Hi Simon
                    Sounds like that stuff is worth using. I suppose you do need a good solid base to prevent the curving which Mike mentioned.
                    Looks good.
                    • JR
                      • May 2015
                      • 18273
                      #175
                      Very nice Simon:thumb2:
                      Have ordered, 2 nd bag arrived, first one never turned up so now in dispute as the seller doesn't respond to messages :angry:
                      • SimonT
                        • 2824
                        #176
                        This one has been progressing slowly in the background
                        It is nearly there now so will be revealed in the not too distant future........
                        • SimonT
                          • 2824
                          #177
ID:	1111428Click image for larger version
                          this ugly monkey is the pilot for the T18
                          cobbled him together from Miniart Russian villager hat and torso with a modified Hornet head
                          looks a little better at normal size and once ensconced inside the T18 will be barely visible so I think he will be ok
                          • JR
                            • May 2015
                            • 18273
                            #178
                            I like the jacket detail Simon. Red star required on hat :nerd:
                            • SimonT
                              • 2824
                              #179
                              Thanks John - face not brilliant though :smiling3: Didn't find many reference photos for early Russian tankers. One with that style of noggin cover didn't appear to have a star on it
                              Well, you will no doubt be glad to know that I am finally calling this one finished
ID:	1111466Click image for larger version
ID:	1111467Click image for larger version
ID:	1111468Click image for larger version
ID:	1111469Click image for larger version
ID:	1111470Click image for larger version
ID:	1111471Click image for larger version
ID:	1111472Click image for larger version
ID:	1111473Click image for larger version
ID:	1111474Click image for larger version
ID:	1111475Click image for larger version
ID:	1111476Click image for larger version
                              Happy Christmas one and all
                              • JR
                                • May 2015
                                • 18273
                                #180
                                Morning Simon.
                                Love the whole idea, works really well coming out of the water like that. The colour of the water and the detail with the water pouring off the rear :thumb2::thumb2::thumb2::thumb2::thumb2:
                                The ice worked out well, looks very churned up, you must be pleased with that .
                                Re the badge, at that time probably the badge was the last thing on the agenda !
