SimonT - Hobbyboss 1/35 Russian T-18 Light Tank
More track links! Don't get them mixed up with all the other ones. Hope the build is all nice and square nowComment
Greetings Master of the Dark side, wish you had started first then I would've have even bothered. :smiling3:
I'll be interested on how you intend to get the tracks on after fitting the guards. I did it the other way round and the tracks were still problematic. Very thin mating points , so some didn't even hold while attempting to fit.
That section of PE was very thick to bend.
Stub axle, ha , broke one pin off , hence the mod on mine.
Yours will be ok , now promise you will finish this as I want to see the tracks !Comment
I will have a jolly good go John
Stub axle is much straighter now anyway
Now for todays problem
on the real thing you can see daylight between engine deck and bottom of turret bustle
not on the kit you don't - turret sits on engine deck
not sure where the problem lies - engine deck too high, turret too low, mixture of both
decided the easiest fix was to add a shim to the turret ring to lift the turret slightly
not the best photo but there is now clearance between deck and bustleComment
When I tried to fit the turret I had to fettle both the parts, managed to get it on and glued it asap ,not that it would have come off without out a fight.:smiling3:
Having slept on it I feel it's just another hurdle crossed. Reading that Simon was also having problems with the fit made me feel it wasn't just me .
Going to start the painting today, then more in the dio.
Thanks for the support Si and Simon .Comment
On the model, the ratio of the height of the turret rear extension to the height of the engine cover appears to be 1:1.20, while on the real tank it looks to be 1:1.13.
The ratio of the height of the turret as a whole (directly in front of the extension) to that of the rear extension is 1:0.63 on the real tank, and 1:0.67 on the model. In other words, the rear part of the turret appears to be too deep on the model, and needs a little removed from its underside.Comment
Yeah, it’d be a pretty major job for such a little correction. It’ll be easier to lower the high part of the engine deck a little, I think, for anyone who wants to open up the gap between deck and turret, but is it worth the trouble?Comment
It would of course have been easier to mod it and the suspension before construction but of course until you fit the turret in place or try to fit the tracks it looks fine
Anyway with the turret ring shim in place there is now clearance and it doesn’t look stupidly out of proportionComment
