M4A1 (76) W & Sherman Dozer (Toon)
    Suspension Mounting Bracket Group: This group used already existing bolt holes in the suspension to make installation easier. Each kit came with brackets to make it work with VVSS or HVSS. The VVSS bracket could be adapted to work with either the M1 or M1A1 blades, the HVSS Brackets could only be used with M1A1 blades, because the M1A1 blade was wider to accommodate the wider HVSS. This bracket and had the pivot points for the blade.
    The VVSS mounts used a replacement suspension cap built onto the blade mounting bracket, and another replacement cap with bolt holes. Another part of the vertical suspension mounting bracket bolted to the unused return roller holes on the middle boggie assembly, the same one that used the built in replacement caps. The replacement cap with extra bolt holes replaced the cap in the front boggie assembly.
    [ATTACH=CONFIG]n[/ATTACH]
    The HVSS mounts were simpler. You just removed four bolts in the first and second suspension arm supports and install the horizontal suspension mounting bracket with longer bolts and lock washers. This is a much easier install than the VVSS mounts, but neither seems overly hard.
    Once you have the mounting brackets on, you get to move onto the…
    Bulldozer Blade Group: This group is basically the blade and it arms that mount to the pivot points on the suspension brackets.This part of the job is where you could really lose fingers or toes. You need a nice flat area, the area you stated in hopefully, and then you drive the tank up to the blade, careful to keep it centered. The tank stops to feet from contact with the blade, and the driver raises the jack piston to the same as the connecting pin on the Blade group.
    This is a multi-person Job, since the co-driver has to hold the quick release cable, in the release position, while the tank is driven into the Jack arms pivot points, and then let the pin close on the eye on the Jack head. The co-driver, while doing this is also guiding the tank into place on the blade arms. At this point the latches on the pivot points can be locked down, a large hammer may be needed and the quick disconnect cable fed into place and loosely connected in the interior of the tank. When it’s pulled the whole assemble will come lose and can be backed out of.
    The final step would be installing the M14 periscope in the drivers position, filling the system with fluids and testing it out. The system was easy to use, and had dual controls, so the co-driver could operate the blade if the driver really needed both hands. The controls were a simple lever used to raise and lower the blade, raising it by hydraulic pressure, lowering it by cutting the hydro pressure and letting the weight of the blade bring it down. Removing the blade was as simple as pulling the quick release cable. If you planted the blade in the ground just right before release, so it wouldn’t move, you could drive the tank right back up to it, hammer the pivot point latches in place, put the pin in the jack and go.
    I have to say this is a very impressive kit. It did make the tank a bit front heavy and probably shortened the life of the front springs, it was not a problem in any real way or the Army would have had modifications made to solve these problems. This kit saw prolific use with the US Army and Marines, and since it worked on any Sherman model, probably everyone else who used Shermans and could get their hands on it. This dozer kit was the most effective way of punching through hedgerows as well, working much better than the dedicated hedge row cutters. A tank company would get one dozer blade equipped tank into the HQ platoon, if there were enough kits to go around. There might be another one in the Battalion HQ platoon.
    Pete.
    • scottie3158
      • 14216
      • Holbeach
      #17
      Pete,
      That was an interesting read, I'm looking forward to the build.
      • minitnkr
        Charter Rabble member
        • 7551
        • Dayton, OH USA
        #18
        Can't go wrong with minions! Great research. PaulE
        • Mickc1440
          • 4779
          #19
          It's a Toon, now where's my seat
            Pete,
            Glad you found it interesting Paul.
            Pete.
              Cheers PaulE and
              Pete.
                Right here sir.
                Pete.
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #23
                  Great to see you back Pete an ive never seen such a colourfull city hall or bank wonderfull
                  chris
                    Hi, so onto the build.
                    Replaced the BMW looka like wheels from my spares box, had to make up some bushes to fit boggie unit axels.
                    [ATTACH]357488[/ATTACH]
                    Made up new rear idler wheels.
                    [ATTACH]357489[/ATTACH]
                    [ATTACH]357490[/ATTACH]
                    Added nuts, bolts, studs, added holes for the return roller bracket to the front .
                    [ATTACH]357491[/ATTACH]
                    [ATTACH]357492[/ATTACH]
                    Fitted replacement three part tran's cover, cut slot in cover made up top tran's bolt strip.
                    [ATTACH]357493[/ATTACH]
                    Cut slot in cover made up top tran's bolt strip.
                    [ATTACH]357494[/ATTACH]
                    [ATTACH]357495[/ATTACH]
                    [ATTACH]357496[/ATTACH]
                    Replaced moulded handles with copper wire
                    [ATTACH]357497[/ATTACH]
                    Added suspension mounting bracket to boggie unit.
                    [ATTACH]357498[/ATTACH]
                    Thank you for looking in.
                    Pete.
                      chris
                      You should see the Toon town paint shop :smiling5:.
                      Pete :thumb2:.
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #26
                        YEA all colours of the rainbow an then some brilliant Pete the colours cheer me up just lookin at em
                        chris ps is Jessica rabbit in residence LOL
                        • stu1664
                          • Apr 2019
                          • 99
                          #27
                          Cracking work as usual Pete - certainly taking these to another level!:smiling5:
                          • Mini Me
                            • Jun 2018
                            • 10711
                            #28
                            Great result so far Pete. Looking forward to the next step.
                            Cheers, Rick H.
                              Hi got the two up hull finished.
                              Added or made lights, brush guards F/R, lifting rings, tools, armoured fuel covers.
                              Dozer Sherman.
                              [ATTACH]357655[/ATTACH]
                              [ATTACH]357656[/ATTACH]
                              [ATTACH]357657[/ATTACH]
                              M4A1 (76) W.
                              Added or made lights, brush guards F/R lifting rings, tools, handels
                              [ATTACH]357658[/ATTACH]
                              [ATTACH]357659[/ATTACH]
                              [ATTACH]357660[/ATTACH]
                                Finish the two turrets.
                                Removed most of the momolded detail, the hatch doors and hinges rotated 20 degrees and filled.
                                [ATTACH]357661[/ATTACH]
                                [ATTACH]357662[/ATTACH]
                                Added M34 gun shied.
                                [ATTACH]357663[/ATTACH]
                                [ATTACH]357664[/ATTACH]
                                Added M/G, handle to hatch, lifting rings
                                [ATTACH]357665[/ATTACH]
                                [ATTACH]357666[/ATTACH]
                                M4A1 (76)W turret.
                                The resin barrel wasn't straight enough so replaced with white tubing, added gun mental lifting eyes, gun pivots,
                                turrrt lifting rings, light /wiring, hatch handles, rear m/g barrel L brackets
                                [ATTACH]357667[/ATTACH]
                                [ATTACH]357668[/ATTACH]
                                [ATTACH]357669[/ATTACH]
                                [ATTACH]357670[/ATTACH]
