Sturmgeschutz III Ausf.G "Finnish Army"
    Stug III G Armour Thinkness.
    [ATTACH=CONFIG]n[/ATTACH]
      Coming along nicely Pete.
        Cheers Andy got to take my time and try and get it right with Mr Stug whatching :flushed:.
        Pete.
        • adt70hk
          • Sep 2019
          • 10416
          #19
          Looking very nice start. Out of interest what is that multi-holed block I keep seeing?
          • JR
            • May 2015
            • 18273
            #20
            Hi Pete.
            Coming on in leaps and bounds at this rate you'll be finished before the StuGmister can find his seat.
              • 18271
              Nice Work Pete.
                Thank you Andrew, the steel blocks are called 123 precision engineering blocks when I'm assembling/gluing I use a steel blocks and magnets on a steel plate to hold everything square.
                  Hi Pete.
                  Cheers John it's getting there, that's the plan otherwise I'll have to take up crochet change my name to Shirley and move out of the country.
                  Pete.
                    Originally posted by Ian M
                    Nice Work Pete.
                    Cheers Ian, I'm just pleased I can almost glue two pieces of plastic together after what's happened recently, but there's still time for me to mess it up :tongue-out3:.
                    Pete.
                    • adt70hk
                      • Sep 2019
                      • 10416
                      #25
                      Interesting......another idea I might have to add to the list.......
                      Thanks.
                        Hi tried to be clever and add a cover surround strip to air intake grill, I know it looks oop: .
                        Will probably turn this into a destroyed wrecked.
                        [ATTACH]360500[/ATTACH]
                        [ATTACH]360501[/ATTACH]
                        Main Gun parts.
                        [ATTACH]360502[/ATTACH]
                        Gun mantlet
                        [ATTACH]360503[/ATTACH]
                        Gun assembly
                        [ATTACH]360504[/ATTACH]
                        Gun Barrel ther or two options, it should have a muzzle brake fitted with flange side deflectors as it's
                        the late one.
                        [ATTACH]360505[/ATTACH]
                        All nicely clamped up drying.
                        [ATTACH]360506[/ATTACH]
                        Main gun assembly.
                        [ATTACH]360507[/ATTACH]
                        Made up rear storage box and added some hinges.
                        [ATTACH]360508[/ATTACH]
                        [ATTACH]360509[/ATTACH]
                        [ATTACH]360510[/ATTACH]
                        Repositioned the two spare road wheel storage mounts to the rear panel because I'm fitting the rear
                        storage box where it would normal go.
                        [ATTACH]360511[/ATTACH]
                        Thank you for looking in.
                        Pete.
                          • 15728
                          Hi Peter
                          Great progress, looking good. The Winter War and the Finnish role in WW2 is a fascinating piece of history.
                          • minitnkr
                            Charter Rabble member
                            • 7546
                            • Dayton, OH USA
                            #28
                            Very clean progress. Once painted I think they'll blend in OK. Thanx for sharing research. PaulE
                              Hi here's a little quiz for you
                              what part on my Stug have I stuck on upside down it's quite a big part and it's at the rear, I've only just noticed oops #**#+-/.
                              Pete.
                              • scottie3158
                                • 14211
                                • Holbeach
                                #30
                                Pete,
                                A very nice build so far mate.
