Seems to me it is a start of a long way. All those screws,rivets and nuts makes me very sad.I already have an understanding that the turret is an separate model.
[ATTACH]415661[/ATTACH]
You very obviously have more patience for this than I would have … I could manage adding rivets with a punch and die set, but probably not drilling holes for the rivets first as well Very good job!
You very obviously have more patience for this than I would have … I could manage adding rivets with a punch and die set, but probably not drilling holes for the rivets first as well :smiling3: Very good job!
Unfortunately it is only a half. It could be easier if Masterclub did such type of screw with this head but.... I don't like to work with PE screws. Drilling and gluing sometimes makes me mad.
Artyom,
Still looking impressive, it will be a shame to cover up all your work with paint - but at least we will know the workmanship that lurks under it.
Mike.
Last month I was very busy at work but some progress could be seen on pictures. I hope next photo session will be the last. Still have to do commander's cupola,antenna basement and holders. Now I can feel the freedom from this model :smiling5: [ATTACH]418788[/ATTACH]
