SimonT - Trumpeter 1/35 Egyptian IS-IIIm
  • SimonT
    • 2824
    Morning all,
    this is another one that I have been chipping away at in the background for some time now
    I have had a concerted effort to finish cleaning up the track links and they are now ready for assembly
    the kit is one of their older ones so not up to their current standards. No etch and rubber band tracks
    In no particular order here are a few pictures I have taken along the way
    fuel tanks - new filler caps and weld seam from filler
    rear smoke drums get etch end plates
    barrel is aluminium tubing with a modified kit muzzle break on the end
    fuel drum mounting holes filled with bits of sheet plastic
    various bits of etch, new bolt heads, lifting eyes drilled open
    welds added to engine deck louvres, grab handles replaced with brass wire and heavy duty welding added with filler
    side skirts scratched from pewter with punched plastic bolt heads
    red paste added for texture
    casting numbers added from Slaters plastic lettering
    tie down strap is from the Eduard etch set
    Masterclub resin links all drilled and sanded
    rear track guard from pewter
    front end from pewter with etch hinge
  • Steve Jones
    • 6615
    I was wondering when this bad boy was going to make an appearance. Lovin the work so far but really interested in seeing the wet stuff on this cracking build
      • 15692
      Hi Simon
      Well worth taking this down from the shelf. So much work done already. "Red paste"?? - go on what is that?
      • SimonT
        • 2824
        Steve - I’m rather looking forward to getting some paint and dust on this one
        Jim - Vallejo textured acrylic paste, great for rough surfaces
          Hi Simon,
          That is looking like a cracking build - do not put it away again..
          Cheers, Mike.
            • 15692
            And there was me thinking you'd been carrying out self mutilation again :tongue-out3:
            • Steven000
              • Aug 2018
              • 2827
              • Steven
              • Belgium
              Interesting build Simon, looking good so far :thumb2:
              • SimonT
                • 2824
                Mike - ta. I shall continue chipping away at it
                Jim - not recently (famous last words). It is this stuff RED OXIDE PASTE
                Steven - thanks
                  Very nice Modelling Simon :smiling3:.
                  • SimonT
                    • 2824
                    Cheers Ralph
                    • adt70hk
                      • Sep 2019
                      • 10409
                      Simon
                      Very nicely done indeed so far.
                      ATB
                      • scottie3158
                        • 14201
                        • Holbeach
                        Simon,
                        I am always amazed and impressed by your eye for detail and your skills in achieving the end results.
                          Steven - thanks
                          That will stop the rust....
                          • Mini Me
                            • Jun 2018
                            • 10711
                            P.C.O. Mr. T, you now have my undivided attention. Nice work so far, glad you are back at it.
                            Rick H.
                            • JR
                              • May 2015
                              • 18273
                              Can't keep up with the amount of builds you have going Simon.
                              Love the rear resemblance to the T34 slope. Pewter out in force :thumb2:
