M1A1 Abrams"Iraq 2003"
    Hi I needed a change from what I normally build so I'm going for modern a Abraham's M1A1 .
    I've never built anything this modern before and most of it will be out of the box.
    Box art.
    [ATTACH=CONFIG]n[/ATTACH]
    Parts.[ATTACH=CONFIG]n[/ATTACH]
    [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
    M1A1 Abrams Walk Around
    Thank you for looking in you should be fun I haven't a clue what I'm doing.
    Pete.
  • spanner570
    • 15401
    Pete, I built one these - Nice kit, but I ain't saying how mine ended up!
    • scottie3158
      • 14201
      • Holbeach
      Pete,
      I will follow along mate if that's ok.
        Hi Ron was it the one with all the rubble because if it is when I finish mine will have more rubble:tears-of-joy:.
        Can you please tell me where it is on the forum so I can look at it.
        Pete.
          Pete,
          Paul you are always welcome you never have to ask . I know one thing it's much bigger than the things I normally build the turret alone is bigger than a Toon tank :smiling5: is it nearly has as many wheels as a Tiger:sad:.
          Pete.
            Well I've made a start cleaned up all the road wheels, idlers and drive sprockets and assemble them, I even remember to put the poly caps in :smiling4:.
            [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
            At this rate I'll have it finished by bedtime :tongue-out2:.
            Thank you all for looking in.
            Pete.
            • scottie3158
              • 14201
              • Holbeach
              Pete,
              That's why I stopped building tanks to many wheels :tongue-out3:
                Pete,
                Wise words indeed check how many wheels are little buggers have got in I get them, you're a thought I would have learnt wouldn't you.
                Pete.
                • spanner570
                  • 15401
                  Pete.
                  Nice, quick progress Pete.
                  My Abrams is on page 6 Completed Dioramas. Here's the link. https/www.scale-models.co.uk/threads/destroyed-abrams-tank-samarra-iraq-2007.30275/ Turns out mine was a Trumpeter kit.... They look all the same to me.
                  I hope you find the pictures useful when you come to do your own 'Rubbling'!
                  • prichrd1
                    • 691
                    • Conwy
                    Now come along Pete, you know Matron won't let you stay up longer than 453 Race!!!!!
                    Looks o.k. so far, I also built one many years ago - with a mine plow !! The Abrams was the easy part,
                    mine plow - gave up after the third attempt !!!! :flushed:
                    Paul.
                    :smiling2:
                    • BigGreg
                      • 2182
                      chair pulled 2nd rank with popcorn
                        Pete,
                        Looking forward to seeing this one, so have pulled up a chair at the front.
                        Mike.
                          Cheers Ron if I get my tank is half as good as yours I'll be happy but if I don't you could have it for extra rubble.
                          Pete.
                            Paul.
                            :smiling2:
                            Hi Paul 453 is on that ward with 24-hours supervision so I don't think matron will be coming round tonight.
                            Don't give me ideas me ideas I'm having trouble building the tank alone adding a plough.
                            Pete.
                              Hi Greg you are most welcome there plenty of room, just had the carpet cleaned so can you keep the mess to a minimum please yes you got it for 453 made a mess .
                              Pete.
