M1A1 Abrams"Iraq 2003"
Hi I've managed to get the base coat on luckily the diorama will be set when the worst sand storm in history happened so you're be lucky to see the tank at all :smiling5:.
[ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
Thank you for looking in hope you like it.
Pete.Comment
Pete.Comment
Hi Pete.
Those additions are perfection , and take this to another level of detail. Hope you are enjoying it as much as we are .Comment
Pete.Comment
Hi detail painting done and just had my first going using Klear and I'm very happy with the results, a small amount on the brush goes a long way, I must thank Scottie for help me out with this, not having to many brain cells I didn't realise you could brush paint his stuff I was always under the impression it was sprayed on which I can't do I will also be trying a new matt varnish a bit later.
I think this is the first time I've actually sealed a hole model.
Pete.Comment
I would like to say thank you to everyone that tries helps me on the forum being able to do it it's another thing .
Pete.Comment
