I decided that as the Honey was as near to completion as is, I would get on and build up the tracks. So spent a couple of hours yesterday working out the sequence I would use and built up a length of 16 links.... Today I finished off the one side length. I decided to check on the full length to see if I needed to add more links, and that is when this glaring problem came to the fore.
Academy kit, with Academy individual track links to keep you busy on a cold winters day, dropped the track gently over the top return rollers and worked my way forward to the drive sprocket. Now in my defence I will say that I used the AFV Club set of suspension and running gear, and I half expected this....
AFV Club version...
[ATTACH=CONFIG]n[/ATTACH]
...So not to be deterred it would simply be a case of take off the AFV Club drive sprockets and add the original Academy drive sprockets....
Academy version...
As you can see - they just do not fit either manufacturer's product, believe me they just do not fit... I tried the unweildy rubber/polythene tracks and yes they do fit but look awfull...
So be warned. More of this will be reported later.
Mike.
AFV Club version...
Academy version...
Mike.
