1/35 SCALE Academy / Zvezda 13506 KV- 2 Tank
  • JR
    • May 2015
    • 18273
    #121
    Originally posted by Mickc1440
    That's a great job John, looks suitably unloved and kept going on basic maintenance
    Thanks Mick .
      Cat - car, got it. god I'm getting old and slow....:rolling:
      Mike.
      • JR
        • May 2015
        • 18273
        #123
        It could have said something else !!!!!!
        • JR
          • May 2015
          • 18273
          #124
          Might be interesting to some this afternoon I took my Ultra Mat varnish , shook it then poured through a filter into shot cup.
          Remember this had been shaken and had 2 s/s ball bearings in. Yet still there were lumps of varnish ,no wonder the ab would stop .
ID:	1113098Click image for larger version
          Will continue to do this with all varnishes in future.
            [ATTACH=CONFIG]n1113098[/ATTACH][ATTACH=CONFIG]n1113099[/ATTACH]
            Hello John,
            That looks a disgusting mess, does your mommy still know you are doing this.....?
            Not had that problem with my Ultra Matt, although If I try Vallejo it is like trying to spray treacle even when thinned. I am near the bottom of my bottle and just given it a shake and all looks well, then poured some out onto a tissue, again no problem. Wonder if it is the varnish sticking to your ball bearings and causing the buildup.
            Mike.
              • 15693
              That looks horrible. What do you use as a filter?
              • JR
                • May 2015
                • 18273
                #127
                Originally posted by MikeC
                Hello John,
                Mike.
                No ! :smiling2::smiling2::smiling2:.
                Could be that, the cave is kept at no lower than 10c 50F , I
                • JR
                  • May 2015
                  • 18273
                  #128
                  Hi Jim.
                  An old pop sock that I nicked from Mrs Race, bit of a fight to get it off her leg though. :smiling:
                  • JR
                    • May 2015
                    • 18273
                    #129
                    This is taking some time to finish as still waiting for some stock to come in from John, mud application is really the thing holding up the water. Don't know how transparent the water would be, personally don't thing you would be able to see much below a couple of inch's /50 mm, but I need to put the mud around the water line first.
                    Have achieved a little using the last dregs of mud around the top of the fenders and stuffed some 12mm grass into the gap under them. When the pour starts I will have to add pieces of vegetation that have been caught up around the tank.
                    Might tone down that green on the grasses.
                    Thanks for looking in .
                      Hi John this is coming together very nicely indeed, now the fun part water and mud.
                      I have my fingers crossed good luck with it.
                      Pete.
                      • JR
                        • May 2015
                        • 18273
                        #131
                        Pete.
                        Cheers Pete.
                        • JR
                          • May 2015
                          • 18273
                          #132
                          Had a good day in the cave, i've been busy painting seafoam sections for a day or so , adding the trunk colors and today the leaves. Also adding grasses to the base , but this late afternoon I start to add the water.
                          Mixing in a little dark umber brown from Vallejo as I went. Using Precision Ice and Snow Water, a two part acrylic material which is great, used it before, no smell or heat !
                          Of course I've run out , b****r, but hey ho that's life. Unfortunately SMS doesn't stock it anymore so have gone direct.
ID:	1113680Click image for larger version
ID:	1113681Click image for larger version
ID:	1113682Click image for larger version
                          Hopefully no leaks ! Will top up the level when stocks arrive .
                          Thanks for looking in.
                          John.
                          • adt70hk
                            • Sep 2019
                            • 10409
                            #133
                            That really is very good indeed.
                            Keri up the good work.
                              John,
                              If you cannot get new stock try Vallejo Water Texture acrylic No. 26.320 Still Water. Self levelling and clear as crystal.
                              But my the fiolage looks damn good, what did you use for leaves on the Sea Foam?
                              Mike.
                              • Steven000
                                • Aug 2018
                                • 2827
                                • Steven
                                • Belgium
                                #135
                                Looks interesting John, nice work on the jungle :thumb2:
