Bronco Comet plus bits....
    Update,
    I started the second layer by first cementing a length of cam net about halway up the side of the turret with pva....
    [ATTACH=CONFIG]n[/ATTACH]
    .... Then started to lay more strips on this but turning the lower part to represent strips that had been bent around as the cam net was gathered up to stop it fouling on the hull. I also wrapped a second layer of net around the barrel and hung strips from this but working the end of the strip in and under the previous net.
    The bottom of the net was then folded up and over the strips I had just placed...
    And this was cemented in place with pva - not pretty at all....
    While this was drying out I then went around the turret again adding more strips and working from about halway down the turret on the first pass and then from the top on the second pass overlapping the lower strips. Once that was complete I then went around looking for 'gaps' that stood out and in need of more work. Then the whole lot was put aside for the night.
    I decided to give the strips a thin wash of brown filter to tone down the whole strips, this has left the net a satin tone but once a coat of matt goes onto the whole model this will be gone.
    And that is it for he net, now back to making up the crew kit etc.
    Mike.
      Originally posted by Jim R
      Hi Mike
      Looks great. I would have imagined that soaking for 24hrs the paper would have started to disintegrate but it looks spot on. Love the kitchen ware.
      Hi Jim,
      Just finished the job, and I would say that after 36 hours the paper will start to become useable but fragile.
      Mike.
        • 15817
        Hi Mike
        That is looking superb. The slight darkening of the colour was a wise move - somehow looks more natural.
        Originally posted by MikeC
        ....... still with hair where it should be and not coming out of your nose and ears,
        Ahhh - definitely one of life's mysteries. Rather like increasing night time visits to the loo. My fear is that ten years from now I'll be spending my days trimming hair and my nights in the loo. Not an existance to look forward to :rolling: :tongue-out3: :sad: :tongue-out: :anguished:
        • Jack L
          • Jul 2018
          • 1277
          • Cheltenham
          #169
          Update,
          Mike.
          Great effect!!!
            Originally posted by Jack L
            Great effect!!!
            Thankyou
            Mike.
              Hi Mike
              Hi Jim
              I agree but the mystery is... we suffer from receding hair loss but then the hair in the nose and ears grows - my theory is that it does not vanish from your head, but comes out through you nose and ears which are attached to you head. The other awkward one is breaking wind, you can sit there all day, but the minute you go to the supermarket and start to checkout - Brrrrpppp it starts - why???? :tired:
              Mike
              P.S. On a lesser important note - the colour does look so much better.
              • scottie3158
                • 14253
                • Holbeach
                #172
                Mike,
                The work on the camp nets is well worth it. They look superb.
                  Update,
                  Most of the build is complete, just a few more bits of stowage to add and antennae, and hopefully a crew, and then it will be onto a base for the old duke. So a few pics to go on with and next time it will be in the completed section.
                  Thankyou all for commenting and looking in, and not forgetting the little bit of banter.
                  Mike.
                  • adt70hk
                    • Sep 2019
                    • 10439
                    #174
                    Mike
                    Apologies for being so far behind with this. As others have said a brilliant build.
                    Very well done indeed!!
                    ATB
                      Originally posted by adt70hk
                      Mike
                      ATB
                      Andrew,
                      Many thanks, and do not worry about being late, the old slow ones have yet to catch up....
                      Mike.
                      • scottie3158
                        • 14253
                        • Holbeach
                        #176
                        Cracking work Mike.
                          • 15817
                          Hi Mike
                          Here's one of them catching up. Quite simply mogglin' as it's best.
                            Update,
                            Work has had to slow down due to SWMBO's brother dying suddenly, so she has been rushing around getting things organised with the rest of the immediate family in Thetford for the funeral which was held last Friday. I was given the job of Dog and Tortoise carer which I undertook with great vigor - decided to let the little runt have the run of the work room, had to dig him out from behind the desk twice, this meant removal of all the kits stowed under the knee area, dig him out, put it all back and later a full repeat.... Later put him in the wet room for a change, turned on the shower to immitate a rain shower, only one of us was supposed to get wet - but we both did...
                            So some work done on the stowage, as the local Homebase did not have the edging strip for the base I needed which will be in tomorrow. So set too and made a bucket, another mug, a medical bag and four small infantry back packs. Plus a large covered set of stowage for the rear engine deck.
                            Medical bag in primer
                            And two views of the large stowage just after the final dirty wash...
                            Mike.
                              Wonderful work Mike.
                              • Si Benson
                                • 3572
                                #180
                                Aโ€™noon Mike,
                                Looking excellent, lovin that cammo netting stuff :thumb2:
