Jim R,
Scottie,
Lee,
Allen,
BigGreg,
Pete Low,
Many thanks for your kind and welcom comments.
No update today as I have caught or been given a b.....y stinker of a head cold, sneezing etc, so every time I held a bit for the model in the tweezers - I sneezed, and every time I looked down, the nose was like a tap/fawcet, I did have three rolls of kitchen tissue, now have none, so just gave up in the end and went and kicked a snail all round the garden, why should he have all the fun eating my peas... So we shall see what tomorrow brings...
Cheers, Mike.
Looking good Mike. I’ve got a Bronco Comet too. I have the turret but not the wheels, looking at the differences I think I need to invest.
Keep up the great work
Paul
Paul
Hello Paul,
There was an article not long after the Comet came out as a kit and this described where you took some tubing and made a saw tooth type end and rotated that around the hub to give the difference depth - then I discovered the AA offering and decided to spend out on the resin wheels as I could not afford the pain and loss of blood. AA still sell the wheels 17.00 plus vat, just checked for you.
Mike
Update.
10 gallons of LemSip later and getting back to normal.....
Continuing on with the rear of the vehicle I started to add the grill work for the intakes along the side of the hull. Here I think Eduard made a mistake in their measurements as there is a 1mm difference in the length - but no matter I just added a 1mm square of rod and attached to end to this....
[ATTACH=CONFIG]n[/ATTACH]
And the grill....
This is the one for the left side, and very fine thin etch - beware.
Next it was the turn of the smoke pot holders, here I had a choice of two (Eduard, Voyager) and the kit version. The kit version was ignored and I decided on the Voyager offering.
The Eduard are the darker ones..
When assembling the Voyager offerings I thought at some point I had grown extra fingers because they just kept getting in the way, but I managed to get one finished. On the second one I ignored the instructions and assembled the tray for the pots first and then folded up one side and the back/top of the main box. I then offered up the pins on the tray to the main body and folded up the last side to close out the build... A thin piece of s/steel rod was cut 7.5mm long and fed through the holes to form the hinge and the handle bent to shape and added. I then took the activator boxes from the Eduard fret and mounted these on the top and the final part was to c/a these in place - job sorted - time taken over two hours....
And there you have the two smoke boxes in place.
Mike.
Hello Paul,
Mike
Hi Mike
Thanks for the info. I’ll be making a purchase with Accurate Armour before proceeding with mine.
Nice work with the PE by-the-way. Any thoughts on markings/unit yet - 11th Armoured?
Hi Mike great work on though smoke pots :thumb2:.
I think it's going to take more than 10 gallons to get you somewhere close to normal
:tears-of-joy:. Hope you feel better mate.
Pete.
Pete.
Hi pete,
Getting there, I think I am over the worst, only hurts when I laugh.... :smiling5:.
Mike.
Update,
HNY to everyone....
Today had a bit more time on the bench and made up the gun clamp and tow bar, no real problems except when cutting the s/steel wire that Voyager give you, wear protective eyewear or cut in side a plastic bag, no John you have the parts in a plastic bag, you stay outside the bag...... I give up!!! Seriously the rod when cut does have a tendancy to fly and peirce even skin...
Anyway here are a couple of pics of what I have done today....
You will notice that the extractor pin pot holes have gone and new bolt ends have been fitted on the side plates...
Mike.
That's a good sign Mike! You take care of yourself Oldtimer...………...
Hello Young 'un,
Good to see you are still with us. I think I have a dose of what you had earlier in the year, but being a resilient old timer we can handle it - nurse, oxygen please!!!
Are you still on with your missile complex, or have you taken a sabatical from it?
Cherrs
Mike.
Yes Mike, I am afraid I had to take a break from it as I need to Paint 6 vehicles and suffered a major brain meltdown from information overload. She will kick back on in the Feb - Mar timeframe. You have been warned!!!
Youngtimer
Good for you, I am trying to clear some of those where you have all the intentions in the world but along comes another - bit like when you discovered girls....
Oldy...
