Scotties Humber Mk1
  • scottie3158
    • 14214
    • Holbeach
    #46
    Originally posted by minitnkr
    Another beauty. PaulE
    Paul, good to see you thanks for the kind comment.
      Scottie,
      Just caught up - brilliant. :thumb2: x 5.
      Mike.
      • adt70hk
        • Sep 2019
        • 10419
        #48
        Scottie
        That really is rather good indeed. Very nicely done.
        Just wish my skills were up to what you've achieved so far.
        This really is going to look very special once finished.
        ATB
        • Lee Drennen
          • 7711
          #49
          like that progress Paul
          • Steven000
            • Aug 2018
            • 2830
            • Steven
            • Belgium
            #50
            Nice interior Scottie :thumb2:
            • Allen Dewire
              • 4741
              • Allen
              • Bamberg
              #51
              Morn Paul,
              Up to your usual handy work I see. Looking tops that Man!!! A quick question that you may be able to answer.
              Did the real vehicle have the tunnel over the front axle? It seems it would be uncomfortable for the driver to drive it with his legs over the tunnel to reach the clutch/brake/gas pedals unless his seat was raised/reclined quite a bit. TIA Buddy!!!
              Allen
              • scottie3158
                • 14214
                • Holbeach
                #52
                Originally posted by MikeC
                Scottie,
                Mike.
                Mike, Praise indeed thanks mate.
                Originally posted by adt70hk
                Scottie
                ATB
                Andrew thanks mate, there is nothing wrong with your skills mate.
                Thanks lee.
                Steve cheers Fella.
                Morn Paul,
                Allen
                Thanks Allen, as far as I can see the vehicle did indeed have the hump over the axle. I can only guess that the seat gave the drivers legs the support they needed but it still must have been uncomfortable and not easy to get in and out.
                • scottie3158
                  • 14214
                  • Holbeach
                  #53
                  Not a lot done. I did remove the moulded louvres as they were far to thick and replace them. The etch towing eyes were added with some punched nuts. The exhaust was also drilled out. Finally the lashing eyes were replaced with 0.3 copper wire.
                  The front suspension was quite fiddley with very small glue points so I let each stage dry thoroughly before adding the next part but before they dried I checked the next part would fit. It builds up to show some nice detail. I will add some brake lines when I add the hubs.
                  cheers
                  Scottie
                    Scottie,
                    Some intricate work going on there, looking well good.
                    Mike.
                    • Peter Gillson
                      • 2594
                      #55
                      Great work - shame so much will be hidden by the wheels.
                      peter
                      • scottie3158
                        • 14214
                        • Holbeach
                        #56
                        Scottie,
                        Mike.
                        Thanks Mike give me a few years and I will be up there with you.
                        peter
                        Thanks Peter, That's why I never normally bother with underneath.
                          You are already there, do not go by my standards, there are much better modellers on here than me.
                          Mike
                          • Steve Jones
                            • 6615
                            #58
                            Not a lot done but it is quality work. Glad you changed the louvers. Wonderful work all round mate
                              • 15733
                              Hi Scottie
                              Fiddly, careful, paintaking work but certainly effective and worth the effort.
                              • scottie3158
                                • 14214
                                • Holbeach
                                #60
                                Steve thanks fella this is a slow build but enjoyable glad you like the louvres.
                                Originally posted by Jim R
                                Hi Scottie
                                Jim, It is not a bad kit but does have a few issues which may be down to me so tweaks are needed here and there.
