Afternoon again.
Recently Pete Low sent me this fine model as a birthday present, so have decided it need to be build and put on show.
I give you the
What a joy to build ! no flash, just a few seem lines to clean up .
Instruction that are clear.
The moulding are clean , all the holes bar one are perfect and with that little clean up every thing fits.
In fact I made more mess sanding the seam line off :smiling2:
Ok plenty of glue, but this was the front ,look how its designed, 4 separate slots for the lugs to fit into , no single seam to attempt a glue line.
Gun as of last night, bit of a clean up needed here, but again a perfect match.
Pete kindly has told me about roughing up the tracks, and the 4 pins that are the attachment points for the upper hull can be reduced. This will be good as I want to paint the track off the kit and fir them after the whole body is painted.
SEATS AVAILABLE.
John.
I give you the
SEATS AVAILABLE.
John.
