Chariot of Fire- Meng Merkava IIID
  • Road of Bones
    • Jan 2020
    • 254
    ”...Bring me my PE of burning gold,
    Bring me my scalpel of desire,
    Bring me my Meng kit, given, not sold,
    I’ll build a Chariot of Fire...”
    Yes, time for me to wax lyrical about IDF machines again...after a pair of Sh’ot Kals, a Nagmachon, a Magach 6B Gal and a D9R dozer, i am drawn to the eternal conflict once more (Mostly because their vehicles are such fantastic modelling subjects, to be honest!).
    (my Magach 6B build, one of my favourites)
    Those of you who remember a certain Devonian hobbit with a fondness for Cider, AC/DC, and the colour green, will recall a man with tremendous generosity of spirit. It was this very fellow who, unprompted, dropped a Meng Merkava IIID through the post to me a year or so back. He’d cut a few wheels off sprues, and misplaced the fret of poly caps, and decided that the subject wasn’t for him, but that I would probably enjoy it- bless the man!
    This is one that I started a few months ago, and I add a bit here & there when I get time. Now I have joined you lot, the mojo is starting to spark again, and I fancy pushing it on.
    So- the kit:
    One of Meng’s earlier kits, but still a goody. I obtained the Eduard PE set, some Chinese Fruils and the ET model PE side-skirts for it over a few months. I also scored the most excellent Desert Eagle book of the Merkava Siman IIID for reference.
    So, a few progress pics to get you up to speed:
    I filled in the crew stowage baskets with liners made from the fingertips cut from nitrile gloves, and added the tie-downs using strips of foil from a packet of scalpel blades. I really couldn’t be arsed sanding off the barrel clamps on the kit one, so made my own barrel from brass tube instead, before adding the PE clamps.
    Detailing the rear of the hull- here you can see the crew stowage bins in position. I added a tarp roll, and the PE mudguards from the Eduard set. The rear crew hatch actually opens btw.
    The forward hull and turret dry-fit- here are the front PE mudguards, you can also just see the PE covers for the various grilles around the front of the hull (remember that the Merkava’s engine is in the front, unlike Western vehicles). These are for “LIC” (Low Intensity Conflict, or Urban warfare) situations, and prevent enemy combatants from chucking molotovs into the grilles.
    Tomorrow, I’ll get on to the turret detailing- hope you’ll follow along!
    Alistair☠️
  • Steve Jones
    • 6615
    Massive fan of the Merkava. Will watch on avidly. Great start
    • BigGreg
      • 2182
      Merkava...chariot (with horses) in biblucal hebrew...i was and l am huge fan of IDF..l light start one in the near future...keep it coming
      • Mr Bowcat
        SMF OG
        • Dec 2016
        • 4600
        • Bob
        • London
        I'm in for this build, I do like a Meng kit.
        Si vis pacem, para bellum.
          • 22770
          I just love the Merkava
          • scottie3158
            • 14201
            • Holbeach
            Al,
            Count me in for this.
              • 15696
              Hi Alistair
              That is a feast for the eyes - lovely detail and so neat.
              • Road of Bones
                • Jan 2020
                • 254
                Good to see so many willing to ride the Chariot with me! (thanks to Greg for the translation- saved me having to do it! :hungry: ). Some new faces for me as well, which is a real bonus! Thanks for your support chaps:thumb2:
                I’ll come back to the hull later, but first I’d like to get the mojo-sapping bit of the build out of the way- namely the RPG screen around the turret bustle. This consists of a skirt of fairly heavy chain, weighted down by steel balls.
                The Meng kit provides this in the form of evenly-moulded panels of balls & chains, that looked really rather unconvincing. I sourced some necklace chain from the web, and a packet of lead-free fishing weights, and decided to see if I could make my own:
                The PE set has perforated brackets from which to hang your chains, and I used fine florist’s wire to join each ball & chain to the brackets. This was taking absolutely ages, and was unbelievably fiddly. I stalled out for several weeks, as once you have a couple of chains attached, they start getting in the way of fitting more. It wasn‘t until I hit on the idea of holding the bracket straight in my etch-bending tool, that I was able to quickly thread all the remaining chains without manipulation problems...et voilà!
                One RPG screen, which swishes about most satisfactorily! You can also see some of the turret PE applied, such as the signal smoke canister holders and the track-hanging hooks.
                Some more turret work here:
                and another view:
                you can see some more of the hull PE here, particularly the LIC screens over the vents.
                Next up, I decided to see what the Chinese Fruils were like. I can report that not only are they cheaper, but they require no drilling, and come with some excellent stiff wire to make the pins (not dissimilar to my preferred method of using old guitar strings instead of the soft brass wire that Fruils provides. I managed to make both track runs in no time at all:
                Not only that, but the wire is such a good fit, I required no glue whatsoever. Two thumbs good!
                More soon, thanks for looking.
                Alistair☠️
                • scottie3158
                  • 14201
                  • Holbeach
                  Cracking work on the chains.
                    • 15696
                    Hi Alistair
                    Great job with the ball and chain screen. Worth the effort. Glad the track is good. Not come across them before.
                      Hello Alistair,
                      Cracking build...
                      Now that you have the mind numbing chains build up and done, there is actually a set you can buy....
                      But I shall sit here quietly...
                      Mike.
                        • 22770
                        Great work looking sweet
                        • stillp
                          • 8093
                          • Pete
                          • Rugby
                          Nice frilly skirt Alistair!
                          • Mr Bowcat
                            SMF OG
                            • Dec 2016
                            • 4600
                            • Bob
                            • London
                            Great work on the chains. Where are the Chinese Friuls from (please don't say China :tears-of-joy.
                            • Steve Jones
                              • 6615
                              Great detailing Alistair. I'm glad the tracks worked out well. If you could PM where you got them from that would be much appreciated
