With a couple of aircraft under my belt it was time for some more armour. I got this as a Xmas pressie from Zoe along with the Lightning, so decided to crack it open, and immediately regretted it.
[ATTACH]372798[/ATTACH]
Looks like it had a hard life in the back of the couriers van as a few parts on the sprue were broken, and 3 of the return roller axles were smashed off the main hull. I managed to find 2 of them so they were glued back on. The broken sprue parts were still in their bags so managed to find and fix all of those.
Lots of bits to deal with, including 4 identical sprues of wheels & suspension. Oh joy.
[ATTACH=CONFIG]n[/ATTACH]
The damaged hull
As usual for Zvezda assembly started with some subs. This time it was these grilles, covers and hatches for the engine cover. The exhausts were just flat with instructions to paint the outlet black, but I hollowed them out the best I could. Might try a bit more now they are fixed in place and easier to handle.
The support for the main turret needed a bit of persuasion and some filler. Will sand that down once it's gone hard and might need to add a bit more
There were plenty of weld beads moulded into this section so where the parts didn't quite meet I added some tiny styrene rod which I'll "sculpt" later, but it tidies the joint up nicely. Sorry about the awful picture!
The damaged hull
