Tamiya M10 IIC Achilles
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4600
    • Bob
    • London
    Hi Guys,
    I decided to break one of my Chrimbo pressies out of the stash over the weekend, I've been looking forward to this one.
    The US provided M10's to the British army during WW2 on the lend lease program. The British, finding the 3" gun rather puny up-gunned them with the fearsome 17 pounder and up-armoured them with additional 17mm plates.
ID:	1115420Click image for larger version
ID:	1115421Click image for larger version
ID:	1115422Click image for larger version
ID:	1115423Click image for larger version
ID:	1115424Click image for larger version
ID:	1115425Click image for larger version
ID:	1115426Click image for larger version
ID:	1115427Click image for larger version
    The build started with the lower hull and bogeys. These went together quickly enough, despite each bogey being made up of 10 parts. Still, they look good and are workable.
ID:	1115429Click image for larger version
ID:	1115430Click image for larger version
ID:	1115431Click image for larger version
    Last night I started on the inside of the upper hull and I'm now at the point where I need to paint and weather the interior. The instructions call out for white on the inside, though research leads me to believe it should be the exterior colour. However I am going with the white, mainly so that some of it should be visible when the turret is on. Call it artistic licence.
    Si vis pacem, para bellum.
  • Jack L
    • Jul 2018
    • 1270
    • Cheltenham
    One of my favorite models as a teenager. I really look forward to your take on it.
      • 15696
      Hi Bob
      Looks a nice kit. A very recent kit from Tamiya so the fit should be good. Looks to have many, many parts.
      60 parts in the bogies alone - :rolling:
      Nice neat start.
      • Bortig the Viking
        • Mar 2019
        • 780
        Hi Guys,
        [ATTACH=CONFIG]n1115420[/ATTACH][ATTACH=CONFIG]n1115421[/ATTACH][ATTACH=CONFIG]n1115422[/ATTACH][ATTACH=CONFIG]n1115423[/ATTACH][ATTACH=CONFIG]n1115424[/ATTACH][ATTACH=CONFIG]n1115425[/ATTACH][ATTACH=CONFIG]n1115426[/ATTACH][ATTACH=CONFIG]n1115427[/ATTACH][ATTACH=CONFIG]n1115428[/ATTACH]
        [ATTACH=CONFIG]n1115429[/ATTACH][ATTACH=CONFIG]n1115430[/ATTACH][ATTACH=CONFIG]n1115431[/ATTACH][ATTACH=CONFIG]n1115432[/ATTACH]
        Last night I started on the inside of the upper hull and I'm now at the point where I need to paint and weather the interior. The instructions call out for white on the inside, though research leads me to believe it should be the exterior colour. However I am going with the white, mainly so that some of it should be visible when the turret is on. Call it artistic licence. :smiling3:
        Hi, hope you can explain, what's the difference between a 3 inch and a 17 pounder, I thought the 17 pounder was 3 inches.
        • adt70hk
          • Sep 2019
          • 10409
          Hi Mark
          You are correct but the 3" gun in the M10 was based on the US 3" anti aircraft gun. The 17pdr whist 3" in diameter was a whole different British beast and much more powerful than the US gun.
          HTH
          • Bortig the Viking
            • Mar 2019
            • 780
            Ahhhh, that's solves that, I've learnt something today, and my wife says I haven't a brain, how wrong she is.
            • Road of Bones
              • Jan 2020
              • 254
              Love the Achilles - count me in Bob!
              I did a dual-build on the old forum with Niho Richizumi (Nick Richardson), where I built the AFV Club one, and he built the Academy one side-by-side on the same thread. I'll dig up a pic of my effort later, if you're ok with that?
              • Mr Bowcat
                SMF OG
                • Dec 2016
                • 4600
                • Bob
                • London
                Thanks guys.
                Jim, I actually miscounted as the wheels were in 2 parts, make than 12 parts per bogey.
                Mark, as Andrew said, although same calibre, it was a much more powerful round. For example compare the bullets from an AK47 and a Accuracy International sniper rifle. Both 7.62 calibre, but the longer 7.62 x 51 of the AI travels much further and faster.
                Alistair, happy for you to post pics.
                • scottie3158
                  • 14201
                  • Holbeach
                  Bob,
                  Great work so far I will follow along.
                  • Road of Bones
                    • Jan 2020
                    • 254
                    Yer ‘tis (apologies to those who saw this first time around):
ID:	1115436Click image for larger version
ID:	1115437Click image for larger version
ID:	1115438Click image for larger version
                      • 15696
                      Don't count them again Bob or you could end up with bogies made of 14 parts!!! :tongue-out3:
                      Like Mark I've learned something - Thanks Andrew
                        And because it’s one of my pet peeves, I’ll have to point out here that the name “Achilles” is usually misused these days Technically, in British service the name Achilles was applied to the entire M10-series: the original version of the M10 (with wedge-shaped counterweights) was the Achilles I, the M10 with “duckbill”-type counterweights was the Achilles II; with a C after the Roman numeral, it indicates a vehicle converted to carry a 17-pounder gun.
                        However, in practice the British Army called the vehicle the “M10” rather than “Achilles”, with the “C” variants being known as the “17-pounder M10” (or similar). The name “Achilles” has been misapplied as referring to the 17-pounder versions only, probably initially by influential authors of AFV-related books in the 1960s and 70s (my money is on Peter Chamberlain and Chris Ellis) and that mistake has crept into just about everything published since.
                        They look good, but purists may notice the articulation is simplified in the same way as the old Italeri Sherman kits (and their Dragon derivatives). But unless you want extreme movement, this won’t be obvious, and certainly not if you place the model on level ground.
                        Going by the American Tech Manual for the M10 that I have on my shelf, the hull interior is mostly white, except the floor, which should be olive drab. The inside of the turret should be the same colour as its exterior.
                        • AlanG
                          • 6296
                          Pics removed
                          And the posting of the pictures was to show which issue/work around? Surely if it was just of a finished build then a LINK to the finished peice would have sufficed
                          • BattleshipBob
                            • 6792
                            • Bob
                            • Cardiff
                            I am in Bob, thinking of getting this for the stash myself. So will follow with much interest!
                              Thanks guys. :smiling3:
                              The ones I put together today only had 11, I feel short changed :smiling5:
