Tamiya M10 IIC Achilles
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4606
    • Bob
    • London
    #61
    Cheers guys.
    For a kit part it was pretty nicely detailed. I did think about putting a black wash over it but I don't think it needs it.
    Si vis pacem, para bellum.
      Originally posted by Mr Bowcat
      I took the time to drill out (what I think is) the cooling jacket
      It’s more the forward support for the barrel (that has a thicker area that sits just inside the front of the barrel jacket) with holes drilled through it so that air can cool the rear end of the barrel too. But yes, the holes are often very shallow on plastic guns, so drilling them out is definitely an improvement.
      • stillp
        • 8096
        • Pete
        • Rugby
        #63
        As the others have said, that MG is brilliant!
        • Mr Bowcat
          SMF OG
          • Dec 2016
          • 4606
          • Bob
          • London
          #64
          Cheers guys.
            Bob,
            Last time I looked you were opening the box....
            Now I have caught up and the workmanship is a pleasure to view, I am a bit dubious with black undercoat, but you have pulled it off to a 'T'. :thumb2:
            Mike.
            • Mr Bowcat
              SMF OG
              • Dec 2016
              • 4606
              • Bob
              • London
              #66
              Cheers Mike.
              Yes, the black undercoat is necessary for the black basing technique, hopefully when the top coats are down I will have you convinced. :tears-of-joy:
              • Mr Bowcat
                SMF OG
                • Dec 2016
                • 4606
                • Bob
                • London
                #67
                Good morning all.
                I got the top coats down this weekend. At this stage I always wonder if I have put enough down as it still looks a little patchy, but usually after filters, washes and weathering it tends to all tie together. I will have another look tonight but I think I'm happy where it is.
ID:	1117948Click image for larger version
ID:	1117949Click image for larger version
ID:	1117950Click image for larger version
                • Jack L
                  • Jul 2018
                  • 1273
                  • Cheltenham
                  #68
                  Looks spot on in the photo's Bob
                  • Mr Bowcat
                    SMF OG
                    • Dec 2016
                    • 4606
                    • Bob
                    • London
                    #69
                    Cheers Jack.
                    • Steve Jones
                      • 6615
                      #70
                      I'd be happy with that too Bob. As you say all the filters will tie it all together nicely
                      • Mr Bowcat
                        SMF OG
                        • Dec 2016
                        • 4606
                        • Bob
                        • London
                        #71
                        Cheers Steve.
                        • scottie3158
                          • 14211
                          • Holbeach
                          #72
                          Bob,
                          Looks to me like a great result.
                            • 15728
                            Hi Bob
                            Definitly looks fine to me.
                            • Mr Bowcat
                              SMF OG
                              • Dec 2016
                              • 4606
                              • Bob
                              • London
                              #74
                              Cheers guys.
                              I'm glad of all the responses as I always doubt myself at this stage. I'll push on with it as it is, if worst comes to worst its an AFV, I'll slap on some mud. :tears-of-joy:
                              • Jack L
                                • Jul 2018
                                • 1273
                                • Cheltenham
                                #75
                                I have just remembered I have a Toon Pershing built, but unpainted. Now I am 'working' from home for the next few weeks, I think I will be giving this paint technique a go.
