A tank called SU
    • 15812
    Hi John
    Looking good. All your little extras/improvements are certainly worth while. The mesh is much better.
    • Road of Bones
      • Jan 2020
      • 254
      #17
      Hi John,
      You do yourself a disservice, as your scratch building and detailing looks great! Youโ€™re straying into SimonTerritory by making your own gun barrels, too
      Really looking forward to seeing your artistry with the wet stuff later...
      Alistair
        John.
        Looking good, love the the lifting eyes and the barrel.
        The welds are good, and I see you've used MR Hobby 500 ? on the side and front to give some texture to the plate. Good idea as the plate was quite rough rolled.
        • wotan
          • May 2018
          • 1154
          #19
          Thanks guys for adding your encouragement. I reckon a bit of mud and dust will conceal the worst of my building. The front end is just about done now, just a few little bits to add here and there. Then I get to move on to the worst bit for me, WHEELS argh.
          BTW John I used Tamiya putty to add the texture. I suspect it will all fade away under the paint anywho.
          • scottie3158
            • 14247
            • Holbeach
            #20
            John,
            Looking very nice with some great looking additions.
            • SimonT
              • 2824
              #21
              Itโ€™s looking good John :thumb2:
                You could have picked a far worse vehicle, then. In fact, you wonโ€™t find overly many better than a T-34(-derivative) in that respect, with only 28 wheels in all, and if you choose the right ones, only a few will even have rubber tyres
                  Thanks for saying what it was John .
                  Hopefully some of the texture will still show through the paint .
                  • wotan
                    • May 2018
                    • 1154
                    #24
                    Thanks for following along.
                    I think the top of the hull is now done. Still have the barrel to fix and I can't decide whether to use the kit fuel tanks or try to remake them. I know what Mr T would do.
Name:	font right.jpg
                    • SimonT
                      • 2824
                      #25
                      Hi John,
                      I used the kit fuel drums but modified them.
                      Built up as per kit then cut off the handles and sanded the ends flat. I then wrapped them with pewter sheet, overhanging the ends to get the thin sheet effect. Then added a weld seam, new filler cap and handles
                      • Mini Me
                        • Jun 2018
                        • 10711
                        #26
                        Sounds like a lot of "Re-Engineering" but I'll bet the end result was worth it. Never thought of layering like that to get the recessed ends like that. Thanks fer the tip Mr. T. John, your efforts so far are way more than I was expecting. I don't think this qualifies for an OOB build, this is a serious build and I look forward to the next installment. Rick H.
                          Hi John bit late to the party, love all the modification work always takes it to the next level.
                          Keep up the excellent work.
                          Pete. :thumb2:
                          • wotan
                            • May 2018
                            • 1154
                            #28
                            Thanks to you all and welcome along.
                            Started on the fun bit for me, painting. Here are steps 1 to 4 so far.
                            1 Primer
                            2 Black to make sure no evil white bits show through the base coats
                            3 My version of 4BO basic
                            4 Some faded green over the top to give the finish a worn look. Just a lighter green sprayed over chipping fluid.
                            Next up some satin varnish, decals then pin washes.
                            This much fun should not be allowed.
                            • Steve Jones
                              • 6615
                              #29
                              Glad your having a fun time John. Nice preparation work
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #30
                                Be careful the "Bug" does not bite you...could very well have another Armour Builder on our hands. Rick H.
