Challenger with enhanced armour.
Update,
Some more work done on the engine deck. Fitted new resin exhaust outlets from AA, made up a new engine cover brace by removing the moulded in item and replacing with etch and rod. Lifting handles are from pre-heated copper wire, the mesh came from Eduard set and the 'bolt heads are from the voyager set.
[ATTACH=CONFIG]n[/ATTACH]
Mike.Comment
Wow! That bin is the DBs and all scratch built! You are indeed the master craftsman. Outstanding my friendComment
Update,
Still on with adding brass to the 2. I finished the turret stowage box for the 1. So now it is full belt on with the Chall 2 and the bar armour.
But here are a couple of pics of the finished turret box.
Mike.
[ATTACH=CONFIG]n[/ATTACH]Comment
