SimonT - 1/35th Tamiya T62 (well worn)
  • Steve Jones
    • 6615
    #16
    Looks like you are having a lot of fun Mr T. Kitbashing is the best part of this hobby. Are you using any AM or will it be all scratched??
    • SimonT
      • 2824
      #17
      Really enjoyed myself yesterday Steve
      Have ordered an Eduard set - may be some useful bits in there but will have to keep in mind that it was designed for an inaccurate kit
      Tracks will be Miniart Omsh bought cheaply - about £5
      Anything else will be scratched
        Impressive
        • JR
          • May 2015
          • 18273
          #19
          Some one is enjoying themselves I think Simon.:surprised:
          • scottie3158
            • 14211
            • Holbeach
            #20
            Simon,
            You are in your element.
            • SimonT
              • 2824
              #21
              [COLOR=rgb(243, 121, 52)]Jakko[/COLOR] - cheers
              [COLOR=rgb(243, 121, 52)]John[/COLOR] - definitely
              [COLOR=rgb(243, 121, 52)]Scottie[/COLOR] - :thumb2: have a perfectly good Trumpeter kit but that is really just an assembly exercise, this is more fun
              stuck the hull on another of my build/painting stands in readiness for the upcoming work
              turret reshaping coming on
              magic sculpt has been sanded back to get basic shape and front end of turret sanded back to shorten it
              I suspect that since they had to lengthen the hull to fit the batteries and motors in they then had to stretch the turret to keep it looking balanced and in proportion
              anyway, now blathered in Squadron green (proper old stuff - my last tube) for (hopefully) final shape tuning
              • JR
                • May 2015
                • 18273
                #22
                Simon .
                This working from home is definitely good for extreme scratchery.:nerd:
                • Allen Dewire
                  • 4741
                  • Allen
                  • Bamberg
                  #23
                  Morn Simon,
                  You are so definitely in your element with these old Tammy kits. Making all the corrections and the fine scratchery too!!! One thing though, I have never seen a turret cake with green icing before............Lime flavored???
                  Bleib Gesund
                  Allen
                    Just knew it, leave him alone and he goes all scratchy.
                    Looking very much the full build Simon, well done.
                    Mike.
                      • 15728
                      Hi Simon
                      Impressive stuff. As Allen says you are in your element.
                      • SimonT
                        • 2824
                        #26
                        [COLOR=rgb(243, 121, 52)]John[/COLOR] - pity they are making us work though. I could have made a lot more progress if it wasn't for that
                        [COLOR=rgb(243, 121, 52)]Allen[/COLOR] - hang on a mo.........bleurghhh, definitely not lime
                        [COLOR=rgb(243, 121, 52)]Mike[/COLOR] - thanks
                        [COLOR=rgb(243, 121, 52)]Jim[/COLOR] - thanks, enjoying this
                        getting nearer to the right shape......
                        • Steve Jones
                          • 6615
                          #27
                          Your wrist must be pretty knackered after all that sanding LOL
                          • SimonT
                            • 2824
                            #28
                            Not too good for the RSI
                              Morn Simon,
                              Bleib Gesund
                              Allen
                              I bet you spend all night licking the tv screen....
                              • SimonT
                                • 2824
                                #30
                                back end tidied up
                                rear panel cut down to fit in the revise aperture and blended in with filler
                                turret has gradually been sanded, filled, sanded numerous times to refine the shape
                                mantlet cover sculpted in Duro around a piece of tubing that creates a socket to fit the barrel in
                                the whole thing was then stippled with vj red oxide paste to roughen up the smooth finish that resulted from all the sanding - once dry it will need a light rub with scotch pad to tone down the pointy bits
