SimonT - 1/35th Tamiya T62 (well worn)
  • Steven000
    • Aug 2018
    • 2829
    • Steven
    • Belgium
    #46
    Nice re-work-stuff Simon, looks great :thumb2:
    Steven
    • SimonT
      • 2824
      #47
      Cheers Steve and thanks Steven
      Turned out much better than the first version - happy with that
      • SimonT
        • 2824
        #48
        a little more fettling then it got a coat of primer
ID:	1119110Click image for larger version
ID:	1119111Click image for larger version
ID:	1119112Click image for larger version
        the cast texture may be a little heavy in places but could always be sanded a little on the resin version if i decide i don't like it so i think it is ready for casting now
        • Mini Me
          • Jun 2018
          • 10711
          #49
          I seem to recall 453 referring to potions and Nostrims of bat wings, frog legs and other surrealistic remedies for such things as this.
          Rick H.
          • Richard48
            • 1897
            • Richard
            • Clacton on Sea
            #50
            Looking great Simon.If castings go well i would buy one from you.Nostalgia build soon me thinks.
            Richard.
            • Neil Merryweather
              • Dec 2018
              • 5197
              • London
              #51
              lovely stuff, Simon!
              • minitnkr
                Charter Rabble member
                • 7546
                • Dayton, OH USA
                #52
                Eye of newt works for me with a little Anal nathrac tossed in. PaulE
                • scottie3158
                  • 14211
                  • Holbeach
                  #53
                  Simon,
                  Outstanding attention to detail
                  • SimonT
                    • 2824
                    #54
                    Thank you all
                    Having looked at it again I decided to tone down the texture a little more then mounted it on a support for casting
                    I also added some small fillets for the pins on the side of the cupola ring to help them cast
                    adjusted fuel tank with new fill and drain caps - will need to cast a few of these off so it is sat on a lump of 2mm plastic card
                    the kit wheel rims are a bit wishy washy so I made some new ones to give a better defined edge
                    • Steve Jones
                      • 6615
                      #55
                      More compass cutting Mr T? Your fingers must be pretty sore after that lot LOL
                        • 15731
                        Hi Simon
                        Very impressed with your skill and attention to detail. Good luck with the casting. You'll need a fair bit of rubber and resin.
                        • SimonT
                          • 2824
                          #57
                          Steve - yes, compass cutting but only 15thou card so no sore fingers
                          Jim - cheers. Yes it will need a few grams of resin
                          • SimonT
                            • 2824
                            #58
                            finished distressing the tyres on the last six wheels
                            then filled the old motorisation holes where the final drive housings should be
                            Tamiya provide a stub axle with a block that fits into the motorisation hole but it is just a blanking plate and has nothing to do with the real tank so this was cut down to just leave the stub axle
                            The holes in the hull were then plated from the back and the fronts built up with scraps of plastic card and green stuff
                            • Steve Jones
                              • 6615
                              #59
                              I hope it all holds well when you put the tracks on
                              • SimonT
                                • 2824
                                #60
                                No problem - will be solid as a rock Steve as all plated in the inside :thumb2:
