SimonT - 1/35th Tamiya T62 (well worn)
  • SimonT
    • 2824
    #61
    Rubber pouring took place last night but I am not holding out for too much hope of success
    Seems my casting rubber has reached the end of its shelf life :sad-face:
    The open tub wasn't too bad but definitely wasn't as runny as it used to be
    Unfortunately there wasn't quite enough left to fill the mould so opened my new tub, which has been sat here a few years, only to find it the consistency of a half set jelly
    I needed so much rubber that I ended up cutting the top off the tub, poured the catalyst and in used it as a mixing bowl
    pouring under way
    the open tub managed to cover the master apart from about 10mm
    since I needed to fill the mould I didn't really have a choice so had to use some of the jelly from the 'new' tub
    it mixed up ok - just wasn't the right consistency to flow very well
    luckily the top 10mm of the master doesn't have any complicated details
    mould is full anyway - remains to be seen if it will be a success or spectacular failure
    Had a look at Sylmasta - the rubber and resin hasn't got any cheaper since I last purchased :surprised:
    will be £65 for a new set!
    • Si Benson
      • 3572
      #62
      Fingers crossed for a result Mr T
      It does look like fun:smiling4:
      • SimonT
        • 2824
        #63
        Cheers Si - yes, it is fun
        Forgot to mention that I also managed to do the mould for the fuel tank at the same time
        • Steve Jones
          • 6615
          #64
          Fantastic dark art work Mr T. Glad you are having fun. Fingers crossed for a successful outcome. :thumb2:
          • Richard48
            • 1921
            • Richard
            • Clacton on Sea
            #65
            Lets hope it all turns out ok.Thats trouble with RTV.I had a Sylmasta lot given to me by a friend and it was like thick custard.As i produce resin busts i get a couple of blokes to help me.I havent facilities to mouldor cast.Im still hoping to do a 62 sometime.Just fetched me Verlinden volume 2 out of cupboard!!.
            Fingers Crossed Simon.
            Richard.
            • SimonT
              • 2824
              #66
              Here’s Steve - you need to try it sometime
              Richard - really annoying that my unopened tub has gone off. I must dig my Verlinden books out as well - not looked at them for years
              • Steve Jones
                • 6615
                #67
                I'm struggling with those screw thread hooks let alone anything as taxing as this! :smiling5:
                  Go one live dangerously, join us on the dark side, nothing like a bit of moulding and casting to get the juices flowing....
                  Mike
                  • Steve Jones
                    • 6615
                    #69
                    This was my last bit of casting Mike for a part the carpet monster got
ID:	1119537Click image for larger version
                    It would have been easier to buy another kit and take the part from that :smiling5:
                    Apologies for hijaking your blog Mr T. Will remove if need be. :tongue-out3:
                      • 15818
                      Hi Simon
                      Don't know what the shelf life of rubber is but I suppose without a BB date a lot will depend on how long it had been held in stock before you bought it. Hopefully it will set and take the detail.
                      • SimonT
                        • 2824
                        #71
                        Here’s Steve??? That was meant to say cheers :smiling2: Blooming predictive text thingy
                        No need to remove - that would be an ideal part for copying. Looking at your castings there are a few things that should have been done to prepare it and make the casting better
                        • SimonT
                          • 2824
                          #72
                          I have asked Sylmasta the question and will let you know if I get an answer - I presume there will be an average life expectancy
                          I‘ve ordered some new resin and rubber - found they now do an XL kit that includes the full size resin and rubber plus mixing cups and sticks and some other bits at slightly less than the cost of buying just resin and rubber separately
                          • Steve Jones
                            • 6615
                            #73
                            I thought you were bigging me up for a big statement on your blog :smiling5: :smiling2:
                            • tr1ckey66
                              • Mar 2009
                              • 3592
                              #74
                              Hi Simon
                              Just caught up with this thread. Looks like you’re having a lot of fun making this old motorised kit accurate.
                              Great skills
                              Paul
                              • Road of Bones
                                • Jan 2020
                                • 254
                                #75
                                I’m rather intrigued to see if the mould rubber has worked ok- it’s like a modelling soap opera! :nerd:
