SimonT - 1/35th Tamiya T62 (well worn)
    Originally posted by SimonT
    I must dig my Verlinden books out as well - not looked at them for years
    I did that a few months ago, and it’s great nostalgia Then I decided to look into obtaining the volumes I don’t have, but if I can find them at all, it’s for much more than I’d be willing to pay
    • Richard48
      • 1900
      • Richard
      • Clacton on Sea
      #77
      Originally posted by Jakko
      I did that a few months ago, and it’s great nostalgia :smiling3: Then I decided to look into obtaining the volumes I don’t have, but if I can find them at all, it’s for much more than I’d be willing to pay :sad:
      Hi Jakko.What volumes of the Verlinden way do you need?
      • SimonT
        • 2824
        #78
        Morning folks - mixed news on the moulding front
        the fuel tank master released from the mould without problem and looks like it will cast ok
        the rubber for the turret has cured and appears to be ok
        it appears though that I pushed the depth of the cupola wells too far - something i did wonder about when pouring the rubber but by then it was a little late of course
        due to them being a bit deep i can not get them to release from the turret master so currently the master is stuck inside a large blue rubber block - what little I can see indicates that it has moulded well though :thinking:
        [COLOR=rgb(209, 72, 65)]UPDATE
        well, using a bit more brute force and a pair of pliers I have finally managed to remove the master from the rubber block
        slight damage to the master turret but fixable if I need to make another mould
        I think I shall have to reduce the depth of the figure bins before trying a casting by slicing some of the rubber off the mould[/COLOR]
        • JR
          • May 2015
          • 18273
          #79
          Hi Simon.
          Very late to this sorry to say. Scratchery in the extreme. Loved the green cake look, followed by the orange going off look. :smiling2:.Just about everything in this build !
          Seems to be your most extreme build yet , brilliance at its best .
          • SimonT
            • 2824
            #80
            Morning John,
            hope you are well
            simple stuff with this one - I think the Tammy Panther A was much more involved as it is so inaccurate
            • JR
              • May 2015
              • 18273
              #81
              Hi Simon, all ok, bit like Jim, can't really settle at the bench, do a bit then off into the garden .:nerd:
              You call that Simple ? :surprised:
              • Richard48
                • 1900
                • Richard
                • Clacton on Sea
                #82
                Hi Simon.Nice to hear some success with the rubber moulds.Im sure the rabble would like to see some pics of castings when done.I stumbled on an article on Britmodeller about improving the Tamiya 62,Apparently the rear deck had a slight incline slope.
                Carry on Carruthers.
                Richard.
                • SimonT
                  • 2824
                  #83
                  John - just a bit of cutting, filling and sanding really :thumb2:
                  Richard - rear deck was sorted when I stitched all the parts back together
                  I will post pictures, good or bad, of the casting
                  • SimonT
                    • 2824
                    #84
                    first casting under way
                    resin was best before 05/2012!
                    Still working though - just the dregs left now so will start new can next time (mind you that’s 6yr old, but unopened)
                    • scottie3158
                      • 14216
                      • Holbeach
                      #85
                      Simon,
                      That is something I have never tried. But it would be a useful skill to have.
                      • Richard48
                        • 1900
                        • Richard
                        • Clacton on Sea
                        #86
                        Looking good Simon.Fingers crossed when they are de.moulded.Drum rolls.
                        Richard.
                        • Graeme C.
                          • 1611
                          • Graeme
                          • UK
                          #87
                          Simon, I'm very interested to see how the castings come out, yet another thing I've never tried.
                          • SimonT
                            • 2824
                            #88
                            Scottie - really handy especially if scratch building multiples of the same part
                            Richard - not so great, read on
                            Graeme - mixed results so far, report follows below
                            took me around half an hour to wrestle this out of the mould only to find that it had a few problems
                            the old resin hadn't mixed too well and the back end of the turret stayed liquid, hence the large parking dent
                            a few air bubbles as well
                            well chuffed with the cast texture
                            opened the newer resin - what a difference, much better consistency
                            filled the turret mould again and had a go at embedding a wire loop inside to aid with de-moulding - assuming it doesn't just rip the turret in half of course :thinking:
                            while I was making a mess I tried the fuel tank and sturmtiger rocket with the newer resin, the previous attempt with the old stuff had the same mix problems
                            worked fine this time around - couple of pin holes but nothing major
                            cast one of my homemade plinths as well for the MG34 figure if he makes it through to basing stage
                            I now have shiny resin fingers with no fingerprints and resin coated fingernails
                            cutting mat also coated in resin as are most other things in the immediate vicinity - I made a bit of a mess
                            • JR
                              • May 2015
                              • 18273
                              #89
                              That's probably why I don't attempt casting, I'd get it every where Simon.
                              The newer mix came out well , think the plinth is very clean looking.
                              • SimonT
                                • 2824
                                #90
                                Morning John - early start
                                I always get in a right mess with it but it is good fun, especially when the castings work
                                I have done a few castings of the plinth - it works well as nice simple shape
                                I have just de-moulded the new resin casting and can report success. A bit of brute force with pliers on the embedded wire had the thing out the mould in five minutes
ID:	1120099Click image for larger version
ID:	1120100Click image for larger version
                                there are a couple of minor air bubbles but I was expecting that as working time for the resin is only a couple of minutes so you don't get long to work out trapped air
                                the three small rods around the left cupola rim have suffered but that is an easy fix
                                pity the crew recesses had to be half filled in but a bit of work with a grinding bit in the Dremel will soon open them out again
                                overall I am well chuffed with the results
