SimonT - 1/35th Tamiya T62 (well worn)
  • SimonT
    • 2824
    #106
ID:	1120329Click image for larger version
    morning all,
    The turret ring side cheeks are way too shallow so I have added a couple of strips to them and clamped in place with pegs
    They will then need some work with the filler to put the curves back
      I was looking at that photo and wondering what it was that you were clamping there Not pulling any punches with this model …
      • JR
        • May 2015
        • 18273
        #108
        Those are great photos Simon, have you upgraded ?
        • SimonT
          • 2824
          #109
          Just done with phone same as usual - got them in focus this time though :smiling2:
          • SimonT
            • 2824
            #110
            reshaping of the cheek parts underway
            also started assembling the gun barrel bits but couldn't get a decent photo
            • SimonT
              • 2824
              #111
              the cheek parts were doubled in depth by adding strip and filler to the underside of them
              this extra material was then sanded back to refine the shape to more closely match the reference photos
              once offered up to the hull it became clear that the basic shape of the top of the kit part was also incorrect, with a definite droop towards the outer edges rather than being flush with the top of the hull
              I decided the best way to tackle this was to mount them on the hull then pack out the bottom edge
              this pivoted the cheek parts such that they then lined up with the hull top
              the whole thing was then blathered in Squadron green to fill all the gaps and change the profile of the edges
              once this sets, which may take a while for such a large amount, it will be all sanded back to the required shape
              • Steve Jones
                • 6615
                #112
                I'm sure you are Heinrich Dorfmann in disguise :smiling2: :smiling5:
                Outstanding work with the green stuff
                • SimonT
                  • 2824
                  #113
                  It will fly Mr Jones....
                  Much more green than it actually needs so that I can sand back to shape
                  • scottie3158
                    • 14211
                    • Holbeach
                    #114
                    Simon have you got shares in squadron green?
                    • SimonT
                      • 2824
                      #115
                      :smiling5:
                      on my last tube of the good stuff - that new stuff just doesn't seem anywhere near as good
                      very sloppy and oozes out the tube as soon as cap removed :disappointed2:
                      • JR
                        • May 2015
                        • 18273
                        #116
                        Simon I'm coming to the conclusion that Squadron Green fumes must have effected you over the years, thus this cause of extreme scratchery also the ingestion of certain potions.
                        Young Jones is not far behind either !
                          • 15731
                          Morning Simon
                          Lovely cheeks. Ladies pay a fortune in Harley Street to have their cheeks done - you may have missed your vocation :tongue-out3:
                          • scottie3158
                            • 14211
                            • Holbeach
                            #118
                            Originally posted by SimonT
                            :smiling5:
                            Simon I found the same so I gave the tube a gentle massage to mix it up then stood the tube on its cap for a few days it is no pretty much but not quite as the old recipe.
                            • SimonT
                              • 2824
                              #119
                              Could be John :tongue-out3:
                              They might not like the green look though Jim
                              Scottie - I have massaged the tube to try mix the contents but not the standing part so will give it a try, ta
                              ground out the turret figure bins, added 3No. new pins around the left aperture and filled the air bubbles - just needs a little tidying
                              • SimonT
                                • 2824
                                #120
ID:	1120764Click image for larger version
ID:	1120765Click image for larger version
ID:	1120766Click image for larger version
                                sanding back and shaping of the cheek parts well under way
