SimonT - 1/35th Tamiya T62 (well worn)
  • Mini Me
    • Jun 2018
    • 10711
    #121
    Half a tube of putty later 'er we are! Just loverly Mr. T. As Scottie says Your shares in Squadron Green must be soaring!!!:tongue-out3:
    • minitnkr
      Charter Rabble member
      • 7546
      • Dayton, OH USA
      #122
      You give a whole new meaning to plastic surgery.:smiling2: PaulE
      • SimonT
        • 2824
        #123
        Morning all - bit more done last night
        finished shaping the cheeks - now about twice the original depth and a better profile
        added the turret ring shot deflector bar thingy - made from two lengths of micro strip, curved and stuck back to back
        the mounting tabs were CA'd to the side of the cheek as per photos, rather than on top as Tamiya have them
        the cheek part was then textured with more of the red paste and a chunky weld seam added on the edges from VJ putty
        just need to replicate it on the other side now....
        • Mini Me
          • Jun 2018
          • 10711
          #124
          Quite an improvement Mr. T.
          • David Lovell
            • 2186
            #125
            Blimey Simon, I get up let cats out let cats back in and feed ,retire to smallest room with tablet start this one from the beginning, quick build my bottom ,mind I should have known better ,as always a master class even those of us not capable I'm sure find it fascinating, , you must have the patience of a zeppelin captain sailing into a head wind,I tend to lose it just box bashing ,please keep it coming, oh dear 30 plus minutes of elbows in knees seems to have caused pins and needles in both legs not the best place for this you could say I've been caught with my pants down Dave
            • JR
              • May 2015
              • 18273
              #126
              Late good morning Simon.
              Those first two photos remind me of a wooden bowl segment after gluing and first turning:smiling3:
                • 15731
                Hi Simon
                The cheeks do look neat and tidy.
                • minitnkr
                  • 7546
                  • Dayton, OH USA
                  #128
                  But prolly have deep dents.:smiling:PaulE
                  • Steve Jones
                    • 6615
                    #129
                    Very nice Mr T. Very nice indeed.
                      ".... turret ring shot deflector bar thingy ....."
                      It's the technical jargon that really confuses us...:smiling5:.
                      This is going to be a great model when finished.
                      Mike.
                      • SimonT
                        • 2824
                        #131
                        Thanks all
                        Mike, I shall try and keep the technical jargon to a minimum for you :thumb2:
                        There has been a bit of progress on this one today
                        Broke out the new copper foil - nice stuff. Very thin so it cuts easily, but more rigid than pewter, so ideal for the track guards
                        Also finished off the curved bars and added the exhaust (cut from the hull during the modifications, assembled and then had the etch end piece added)
ID:	1121128Click image for larger version
ID:	1121129Click image for larger version
ID:	1121130Click image for larger version
ID:	1121131Click image for larger version
ID:	1121132Click image for larger version
ID:	1121133Click image for larger version
ID:	1121134Click image for larger version
ID:	1121135Click image for larger version
ID:	1121136Click image for larger version
                        the curved bars sorted around the cheek parts and then the smaller segments added front and back on the hull top
                        exhaust added back on to the hull side - position based on reference photos that show it further to the rear than Tamiya had it
                        this left a hole in the hull side that had to be plugged before the track guards could be installed
                        track guards made from copper sheet with the edges bent in an etch bender
                        impressed pattern on the front ends made with a ball end embossing tool
                        looking a bit more tank like again
                        • Steven000
                          • Aug 2018
                          • 2829
                          • Steven
                          • Belgium
                          #132
                          You make it all look so easy Simon! :tongue-out3:
                          Great work for sure! :thumb2:
                          Steven
                          • Road of Bones
                            • Jan 2020
                            • 254
                            #133
                            Nice work Si- that Copper sheet looks very satisfying to work with, and I can see the benefit of the embossing tool now. One of my favourite things on this, oddly enough, is the perfect (interrupted) circle of turret-ring shot-deflectors you have achieved :thumb2:
                            • SimonT
                              • 2824
                              #134
                              Steven / Al - thanks both. Al,the circle isn't actually circular - the front ends of the bars over the cheek parts are pulled in towards the hull so it is more egg shaped
                              The copper sheet is nice stuff and will no doubt feature on future builds
                              added a few bits to the turret
                              track bump stops and track pin relocating device (just a big lump of steel that the pins smack against) added to the lower hull
                              • Strenko J
                                • May 2018
                                • 752
                                • Joe
                                • Pittsburgh PA
                                #135
                                Just fantastically masterful piece of work going on with this build Si...keep it coming
