1/35 Bronco Bishop SPG - forum choice
I looked it up, and I did indeed see the photo Graeme posted in Military Modelling — to be precise, Vol. 40, No. 14 (26 November 2010), on page 30. The caption for this picture points out:—
Note that while the turret interior is painted white, whereas [sic] the inner face of the doors is darker, i.e. still in SCC2.Comment
Jakko,
thanks for that! I think I'm going to paint the drivers' compartment silver, and the internal faces of the hull the same. The internal of the fighting compartment white, along with any gear fitted to fit the 25pdr. It's going to be a matter of what is visible, in the end!
DaveComment
Wheels assembled to the suspension - for some reason, the wheel inserts are keyed to fit in a particular orientation - why, I don't know. You can't see both sides of the wheels & there are no through holes to line up - either way, it makes them difficult to assemble.
Each track link has 3 sprue attachment points, but with a new scalpel blade, there's no cleanup needed. The only tricky bit is their size, big fingers don't help. They fit snugly together - I don't think you could call them 'working' tracks, but I think wrapping them round sprockets/idlers is going to be relatively easy. Photos show the Bishop with and without sand shields - I think generally those in North Africa had them fitted - those in Sicily had them removed, but it's difficult to be positive. This makes quite a difference - the sand shields hide the top run of the tracks, so a bit of tedious work can be saved!
DaveComment
A little late to the party I'm afraid Dave. Looks a wonderful kit and I like what you have done to it. I agree with the interior paintwork scheme you are going for. It doesnt make a great difference but the white the British used was gloss so you may want to add a bit of gloss varnish to the white that you use or give it a gloss varnish finish once done. I have a few interior pictures for you. Please remember the colour photos are from someone adding the colour themselves rather than actually taking a colour photo so their intereptation should be taken with a pinch of salt. If you require any outside photos of the Bishop let me know.
I really hit a wall over the weekend - I sat down several times at the bench, and couldn't raise any interest - I looked at the Bishop & I looked at my pair of Mittens, and just didn't feel like doing anything - a real fine time to lose the mojo!
At the moment, it's getting difficult to distinguish what day it is - I had to look up when Good Friday was ( 10th ), and holidays have no meaning in present circumstances.
Instead, I've been doing a little retail therapy - On ebay, I bought several books, none of which seem to be available as ebooks. Otherwise, I've ordered a couple of submarines - I feel that I must try & do a seascape, so I spent several hours researching models, then finding the best deal. I'll post them up when they arrive..............
DaveComment
Back to the bench! I've put away the track links for the moment & moved onto the interior - primed & basecoated.....................
The steering levers are a really tricky part to assemble - 5 bits with minimal glueing area - any way I'll just give the seat cushions a touch of paint, because, when the upper hull is added......................
I've still got the gun mounting, the gun & the upper box superstructure to add, so any additional detail in the drivers compartment will be a waste of time!
DaveComment
Hi Dave,
SWMBO put me on the right track when i started to lose the mojo, get out a fiction book and spend a couple of hours reading - Dirk Pitt and me have become firm friends.... Trouble is we used to have so many other things going on in our lives, and now we have all the time in the world to do what we enjoy, some of the haste has been taken away.
Like the work on the interior.
Mike.Comment
