Definitely some complex parts in this one & odd build sequences in the instructions Dave, but your doing well all the same.
1/35 Bronco Bishop SPG - forum choice
Nice sunny morning here, listening to the wood pigeons cooing & wooing.................
I fitted the rear engine doors - rather puzzled. as I can't see any hinges in the instructions - there's a hole, but nowhere in the assembly can I find anything to put in it!
I decided to look at how MiniArt do this on their Valentine, and found something odd......................
MiniArt Valentine Instructions
If you look at the Bronco Instructions for the same assembly:
The Bronco has a few more parts, but look at the part numbers - they're so similar, it can't be a coincidence!
According to Scalemates, there's no connection between Bronco & MiniArt, but...........................
DaveComment
Upper deck primed & basecoated................................
I've still to add the exhaust heat shield & tools, but that part is finished. The Gun & tower can just about be finished as a separate assembly. If I thought some of the hull was tricky & overengineered, then the gun is at a new level!
DaveComment
After almost a week, I'm back to the bench. I've had a bad back, which has meant that I have spent a lot of time lying down. It's now just very stiff, but I can at least sit properly.
I've added the tracks & united the upper & lower hull.........................
I'm not going to add the top track runs, they will be hidden by the sand shields. The individual track links aren't particularly difficult, just annoyingly fiddly and boring, so no point in spending time on something that won't be seen
DaveComment
On to the gun...............................
A really overcomplicated assembly, not helped by one actual part bearing no resemblance to the drawing - I hunted on all the sprues, to find a part that resembled this, but no. This is 17 parts ( I've omitted two tiny PE parts )
I can understand making the breech able to be assembled open/shut, but Bronco would have you make it as a working part, opened by the breech lever - no way!
The mounting for the gun is one of two options. The instructions don't say if they are late, or early, or apply to a particular theatre - I'm going to look, and see if one is easier to make than the other.
DaveComment
Dave,
Ref similar parts and instructions, I have a Tamiya Bradley and Academy Bradley same parts and part numbers.
You say you seem to be doing a lot for what looks like little return - we can see it.
Mike.Comment
