Andrew's wife's 1st model - 1/72 IBG Pz IIIa - should I apply a filter?
  • Si Benson
    • 3572
    #31
    Hi Andrew,
    looks like Mrs Andrew is pretty nifty with the airbrush! Well done that man woman :thumb2:
      Great stuff. Now you can concentrate on building and sublet the spraying to her :smiling5:
      Originally posted by adt70hk
      Her trigger action in particular was very nice and controlled and soooooooo much better than my ham-fisted efforts when I first picked up and AB.
      She sounds better than I still am lol. It's still very much a surprise every time I pull the trigger as to how much going to come out :smiling5:
      • adt70hk
        • Sep 2019
        • 10445
        #33
        Hi all
        So we decided to add some brown camo as per the instructions and after having got confirmation online as follows:
        "On 19 July 1937, it was ordered to change the camouflage pattern to Dunkelbraun Nr. 45 (dark brown) and Dunkelgrau Nr. 46 (dark
        gray), with feathered edges. Vehicles already painted in the Buntfarbenanstrich were not to be painted in the new pattern, unless they
        were to be re-painted anyway."
        Source panzerworld.com/german-armor-camouflage
        I think you'll agree it came out ok for her first effort.
        ACW as usual.
        ATB
        [ATTACH]381729[/ATTACH]
        [ATTACH]381730[/ATTACH]
        • monica
          • Oct 2013
          • 15169
          #34
          good on her,so glad to see it,job well done :smiling:
          • prichrd1
            • 694
            • Conwy
            #35
            I think you'll agree it came out [COLOR=rgb(209, 72, 65)]ok[/COLOR] for her first effort.
            OK?? OK?? is that all you can say? :rolling:
            That's an excellent result, first model built, first time using airbrush ?
            (That was a practice run with the undercoat).:thumb2::thumb2:
            Spent most of my modelling trying to get that kind of result!
            Now for the tricky part - a little weathering perhaps??
            Paul.
            :smiling2:
              You got to hand it to the good lady Andrew she's damned good .:thumb2:
              • Mini Me
                • Jun 2018
                • 10711
                #37
                I like that!!! Way better than my first attempt. :thumb2:
                Rick H.
                  • 18959
                  Nice job. Better than my first attempt as well!
                  • yak face
                    • Jun 2009
                    • 13875
                    • Tony
                    #39
                    Great job mrs andrew , youre a natural , cheers tony
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #40
                      Rick H.
                      Same here I dint do a good job got the shakes on the first an last attempt as I borrowed a friend A/B an I though It was rubbish so Andrew your good lady is good :thumb2:
                      chris
                      • adt70hk
                        • Sep 2019
                        • 10445
                        #41
                        Paul.
                        :smiling2:
                        Rick H.
                        chris
                        All
                        Thanks for the great feedback and for the support I'll make sure she reads the comments later!
                        Paul - You are probably right about my 'OK' above but you have to understand that I have made understatement something of an art form! In fact if they allowed pictures in dictionaries you would just see my face against the entry!! I will therefore try and be more effusive in my praise of her efforts in future posts!! :smiling: Next up before weathering is painting the tools and tracks.
                        Thanks again all for taking the time to respond.
                        Yours
                        • prichrd1
                          • 694
                          • Conwy
                          #42
                          Ah yes I know how that goes - first it's a model - then it's the bench - then the stash!!
                          Need me to go on???? :flushed: :smiling2::smiling2::smiling2:
                          Paul.
                          :smiling2:
                          • scottie3158
                            • 14261
                            • Holbeach
                            #43
                            Nicely done
                            • adt70hk
                              • Sep 2019
                              • 10445
                              #44
                              Thanks Paul. Much of appreciated. I'll make sure I pass your comments on.
                              ATB
                              • adt70hk
                                • Sep 2019
                                • 10445
                                #45
                                Hi all
                                So at some point in the process I was thinking of applying a lighter grey filter to lighten the tank up a bit as the base colour is a bit on the dark side and also to blend the brown and grey a bit better.
                                I've only done a couple of times and so am still very much learning about them and how they behave.
                                Am I on the right lines or would another approach be better?
                                Thanks always in advance for your ideas.
                                ATB
