Next build folks
  • BattleshipBob
    • 6799
    • Bob
    • Cardiff
    #16
    This is not fiction by fact, i have finally dragged myself back to the bench :surprised::thumb2:
    Had a rough 10 days or so but very grateful that i have not had the full blown virus and the awful headaches are better, not 100% but eating more and sleeping less:tongue-out3: lost 1/2 a stone
    So if you have joined in this thread you will have read that the A(2) was a StuG hybrid, that is a completed Pz 111 hull but with a StuG superstructure added and in this case a Pz 111 F hull.
    The kit being a typical Dragon comes with a mountain of extra bits including the side escape hatches but they were welded shut on the A(2), so began by added these to the hull sides, thankfully the shadow of the hinges locating holes was there which enabled me to drill the center hole and accurately fit the hinge. I then had to sand off the outline on the hull side and back of the escape hatch covers
    I used thin plastic rod to hopefully replicate welds, you can see by the tiny scratches where i used the tip of a blade to cut into the rod!
    Not sure how effective they look, would appreciate feedback and yes more clean up needed :thinking:
    Blasted camera never lies as we all know :angry:
Name:	Stug A2 001.JPG
Name:	Stug A2 002.JPG
    Thanks all, been a while but at least I am back at the bench for short periods for the time being
    cheers bob
    • SteveH
      • 1287
      #17
      Hi Bob
      Good start though it might be too irritating to improve the weld detail too much more
      I would use extra thin to soften the sprue then use the back of the blade tip to create deeper weld detail, though it is getting there and after dust and weathering would be OK as it looks sealed up
      HTH's?
      Steve H
      • boatman
        • Nov 2018
        • 14479
        • christopher
        • NORFOLK UK
        #18
        Blasted camera never lies as we all know :angry: SO you want your camera to lie then Bob shame on you blamein the poor old camera lol :confounded: not its fault for showin how good your work is as it looks great to me but then im not a tanky I wouldn't know if its right or wrong but looks great to me keep on chuggin boyo an glad you are feelin better
        chris
          Looking pretty good already. You can probably check better if you paint the hatch and its surrounding area, so they’re all the same colour — it’s often surprising how much more easily you can judge texture that way than if you’ve got different colours of materials together.
          • tr1ckey66
            • Mar 2009
            • 3592
            #20
            Hi Bob
            I’m with SteveH. The weld looks fine enough but I would soften it and create the weld with a scalpel. I find it easier though to create my welds with ‘worms‘ polymer clay and shape with a suitable tool.
            Paul
            • BattleshipBob
              • 6799
              • Bob
              • Cardiff
              #21
              Originally posted by SteveH
              Hi Bob
              HTH's?
              Steve H
              Hi Steve, sound advice thanks! Only second bash at welds. Over did the glue a tad, will get out the fine sanding sticks to tidy up. Used the front not back of the blade, thats one tip to remember!
              chris
              Thank you Chris, much appreciated. Better thanks, getting there!!
              Thanks for looking in Jakko
              A bit of dust should hide the worse bits!
              Originally posted by tr1ckey66
              Hi Bob
              Paul
              Hi Paul
              Might try that and see how they compare. Many thanks bob
              • JR
                • May 2015
                • 18273
                #22
                Apart from flames being recommend, I think just soften the outer lines, still it looks good to me Bob.
                Sorry to read you've been feeling worn out again.Think you should put your feet up to,morrow and sit in the sun. ( of course plastered in 4 BO Sun cream ) :nerd:
                • SteveH
                  • 1287
                  #23
                  Hi Bob
                  Night Shift on You tube has some fun weld tutorials too.
                  Steve H
                  • BattleshipBob
                    • 6799
                    • Bob
                    • Cardiff
                    #24
                    Good idea John, now after using 4Bo cream i would look like a ugly Shrek lol
                    Thanks Steve, i do like his work, will have a look:thumb2:
                    • Graeme C.
                      • 1604
                      • Graeme
                      • UK
                      #25
                      Good to see you're feeling well enough for a bit of bench time Bob.
                      • BattleshipBob
                        • 6799
                        • Bob
                        • Cardiff
                        #26
                        Thanks Graeme, appreciated!
                        • BattleshipBob
                          • 6799
                          • Bob
                          • Cardiff
                          #27
                          Back at the bench. Almost finised hull.
                          Decided to allow the wheels/suspension to move, so only glued the torsion bars at one end and cut off the swinging arms locating pin. Sadly cannot do this with the first/last arms as the fitted damper is solid.
                          Now, for a first bash at a dio, so using a base i bought and made a while back. I have some 1 35 bricks somewhere, but photo shows a damaged telegraph pole. Click image for larger version
                          Bob
                          • boatman
                            • Nov 2018
                            • 14479
                            • christopher
                            • NORFOLK UK
                            #28
                            Now, for a first bash at a dio, so using a base i bought and made a while back. I have some 1 35 bricks somewhere, but photo shows a damaged telegraph pole. [ATTACH=CONFIG]n1120999[/ATTACH]
                            [ATTACH=CONFIG]n1120997[/ATTACH]
                            [ATTACH=CONFIG]n1120998[/ATTACH]
                            Bob
                            HI Bob really good to see you modelling again so hope you are feelin better an the build is comin on great be nice to see you do a dio
                            chris
                            • BattleshipBob
                              • 6799
                              • Bob
                              • Cardiff
                              #29
                              Thanks Chris, trying to do at least a hour a day, biggest problem is my up and down energy levels, right pain.
                              • boatman
                                • Nov 2018
                                • 14479
                                • christopher
                                • NORFOLK UK
                                #30
                                WELL Bob at least you are back a little a day an it will keep you happy
                                ATB chris
