Can see your point Tim, asked the misses if i could drive her car (not mine) into one to see what happened, she said no, bit unfair i think
That is just damn un-cooperative of her, I would have asked mine to do the driving so that for technical reasons (insurance) I could observe the impact. As for teeth, who needs them, they are only there to stop you putting more cake in... :tongue-out3:
On the final straight. Interior finished but not fitted, i will paint the gun cradle seperate to the floor to hopefully make it easier
The position of the ammo racks on the plans is terrible with no locating holes or even a outline!! It does show the stick grenades on the rear mounted ammo bin but strictly they were fitted from Ausf D but will be a nightmare to remove so they are staying! The rear ammo bin is held by masking tape and again no locating pins.
Looking good Bob.
Agree with Tim with regards to the telegraph pole. I think it would be more realistic laying on the ground in front of the T-34. Perhaps you could even have a ball of concrete/earth/pavement at the base which has been torn from the ground with it?
To save yourself some time and money I’d first create the uneven ground with polystyrene then cover that with the rubble. Looking at period photographs of many bombed out and cleared streets it’s amazing how much rubble there is to a knocked down building - up to 2 storeys high! This could be the scene at the edge of such carnage but i think the pile should be the lower slopes of a much bigger pile. This will give the rubble some context and add to the realism.
It’ll be a nice busy scene and I look forward to seeing the progress.
P
Now that my doc has agreed that i can go out for a short stroll and very nice too!!
So finally returned to the garage, hoovered all the cr*p off the bench and primed the interior with Mr surfacer 1500 50/50 with mr color thinner. Will leave for a day then red and ivory interior, very impressed at how well it sprays
Will remove the rear wall before the red oxide
Primed the ammo boxs, and the radio pannier, gun and its cradle
Not a lot but pleased that i did not co*k it up, been a good few months since i last picked up a airbrush!!
Think the guys are right about the telegraph pole, more sort of pushed over with loads of soil and concrete around the base.
Whats this slur on T34 drivers anyway, knocking down poles, never, all highly trained having converted from using horses and carts.:smiling:
4BO Rules.
Many thanks Steve, how are you?? Only problem the horrible garage!
Looking good Bob.
Cheers Tim, appreciated!
Nice primer paint work Bob.
4BO Rules.
It was either ram the StuG or the pole, of course the T34 would bounce off the handsome StuG. Thanks John, now what is this 4BO larky:thinking:
Great to see you back painting. Very tidy work my friend
Good to hear from you Steve, steady as she goes!!
Now todays progess however it did not start well. Airbrush did not behave, thought it was the lacquer, so stripped brush, made another dose of paint BUT again sprayed terrible, so stripped again (swear box over flowing by now) then looked at the pressure gauge and yes only reading under 10 psi D'oh, simple adjustment and problem gone, BUGGER:disappointed:
So used MRP red oxide and what a lovely paint to spray, superb.
Then used Tamiya racing white, to spray the rear wall and ammo bins and cradle, although not sure??
