Andrew's 1/72 Armourfast Panther G - paint and decals
  • adt70hk
    • Sep 2019
    • 10402
    Hi all
    So this started X years ago elsewhere and I've finally got it to the point where it is now has decals.
    The idea was to take one of these super simplified wargaming kits - £7.50 for two kits, a whole tank on each sprue and with only 20 pieces per tank - and 'tart' them up.
    Below are a few pics of the in progress shots so you can see what I did to get it to where it is today. The zimmerit worked better in some places than others and was done using 'No More Nails' glue and and a 32 TPI junior hacksaw blade.
    ACW as usual.
    Yours
    A very basic sprue!!
    [ATTACH]380813[/ATTACH]
    Build finished
    [ATTACH]380814[/ATTACH]
    [ATTACH]380815[/ATTACH]
    [ATTACH]380816[/ATTACH]
    [ATTACH]380817[/ATTACH]
  • Steve Jones
    • 6615
    Some nice additions Andy which have painted up well. Lovely work my friend
    • adt70hk
      • Sep 2019
      • 10402
      Thanks Steve. I'm really pleased how it came out, especially considering the base kit was so basic and plus it was only my third go at German tri-colour camo.
      ATB
      • adt70hk
        • Sep 2019
        • 10402
        Hi all
        So a little over 8 that EIGHT years after a I started this, it is finally finished. I was inspired to get it over the finish line when I finished my Jagdpanthers.
        To finish it off I simply added a clear coat ahead of some light weathering....basically some light chipping and a mixed sepia/umber pin wash to bring out the details, followed by a final matt clear coat.
        This won't set the modelling world alight but just remember is started life as a £3.75 quick build wargaming kit with no detail to speak of....AND when I was a far less experienced modeller than I am now! Also it was one of the first kits I airbrushed and did so using a cheap Chinese one that came with my compressor.
        I'll do a proper completed post with more pics shortly!
        ATB
        • A_J_Rimmer
          • May 2024
          • 801
          • Arnold
          • North Wales
          That is blooming lovely, if my builds came out looking anywhere near as good as that I'd be happy.
          Arnold Judas Rimmer BSc SSc
          ''Happiness is a Triple Fried Egg Sandwich with Chilli Sauce and Chutney''
            • 15669
            I thought I was a slow builder but eight years must be some kind of record. That is a great result especially given the scale and the bargain price.
              I bought that set too, for wargaming, and felt that what I got in the box was so awful that the best I could do with it was turn them into Pantherturm bunkers … (I could show pictures if you want ) In other words, you’ve done quite a creditable job with this kit, given how poor it is.
              • adt70hk
                • Sep 2019
                • 10402
                Originally posted by Jakko
                I bought that set too, for wargaming, and felt that what I got in the box was so awful that the best I could do with it was turn them into Pantherturm bunkers … (I could show pictures if you want :smiling3: ) In other words, you’ve done quite a creditable job with this kit, given how poor it is.
                Thanks chaps. I was quite pleased given where it started from!
                In case you missed it the full completed thread is here......https://www.scale-models.co.uk/threads/andrews-1-72-amourfast-panther-g.43480/
                Jakko - would like to see what you did with them as Pantherturm's. Please feel free to put a couple of pics up on this thread, so people can do a comparison.
                Thanks again.
                ATB
                  What I did was build the turret, but without the cupola, adding a thicker roof (turrets for Pantherturm bunkers had that) and a simple scratchbuilt hatch for the commander. Then I built the top of the bunker from card, household filler and a scrap bit of plastic pipe from dimensions taken from real-world drawings I found online. I put this on a blank DVD:
                  [ATTACH]509966[/ATTACH][ATTACH]509970[/ATTACH][ATTACH]509968[/ATTACH]
                  I also built two more bases for which I glued the upper hull to a blank DVD too, building up groundwork around it with filler again. Though putting the turret from above on this is not 100% correct for a dug-in Panther, it gives just a little bit more choice for wargaming
                  [ATTACH]509967[/ATTACH]
                  BTW, with “blank DVD” I really do mean that: DVD discs without any coating on them to take the data. About ten years ago, I was somewhere that had whole stacks of them (they had apparently been used as dividers in boxes full of shaped DVDs), so I asked if I could have some. When I explained I could use them for crafting things (I didn’t bother trying to explain their use for wargaming terrain ) I got a stack of over 20 cm of them. And have so far used them for … these four Panther bunkers
                  [ATTACH]509969[/ATTACH]
                  And in use in a game:
                  [ATTACH]509971[/ATTACH]
                  Which shows very well why I wanted the blank DVDs, I think.
                  • adt70hk
                    • Sep 2019
                    • 10402
                    [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
                    I also built two more bases for which I glued the upper hull to a blank DVD too, building up groundwork around it with filler again. Though putting the turret from above on this is not 100% correct for a dug-in Panther, it gives just a little bit more choice for wargaming :smiling3:
                    BTW, with “blank DVD” I really do mean that: DVD discs without any coating on them to take the data. About ten years ago, I was somewhere that had whole stacks of them (they had apparently been used as dividers in boxes full of shaped DVDs), so I asked if I could have some. When I explained I could use them for crafting things (I didn’t bother trying to explain their use for wargaming terrain :smiling3: ) I got a stack of over 20 cm of them. And have so far used them for … these four Panther bunkers
                    Thanks jakko for that. They've turned out not too bad for what you needed them for!
                    • Scratchbuilder
                      • Jul 2022
                      • 2689
                      From a cheap basic kit to a little gem and fitted out with Zimmerit, well done.
                      • adt70hk
                        • Sep 2019
                        • 10402
                        Thanks Mike. It's turned out nicely all things considered.....in case you missed it there are more pics here: https://www.scale-models.co.uk/threa...nther-g.43480/
                        ATB
                        • Lee Drennen
                          • 7711
                          Andrew very impressive like mike said what a little Gem.
                          • adt70hk
                            • Sep 2019
                            • 10402
                            Lee,
                            Apologies, completely missed this! Thanks for stopping by and glad you like it!
                            ATB
