I made a start on this yesterday and wasn't sure about blogging it, as frankly it's a bit dull. Hopefully I can spice it up with the paint job.
More of a concept vehicle, designed by the Polish company OBRUM, with help from BAE Systems (one of my wife's customers), it has an unmanned turret with automatic loading of the main gun, and a remote control module which is shown in the kit holding a machine gun, but other options are available.
There aren't many parts to the kit, in fact apart from the wheels, most of them are used for the remote machine gun. Here are some sprue shots, also showing the rather excessive packaging for the tiny PE fret!
Main hull and side armour
Running gear & tracks
Turret base, guns and rear panel
Turret, track jig and humongous bag for the PE
There's some nice crisp detail moulded into the parts, even though all of these will be virtually hidden once complete.
Construction started with the suspension arms. Here the track jig doubles up to help ensure they are all in line, even though each part is keyed and a tight fit so there's little chance of getting it wrong anyway.
Then the jig is used to aid assembly of the link & length tracks. Probably a straightforward job for most of you but I found it to be like juggling an octopus. When finished most of the track is hidden so you could probably leave most of the top run out if you wanted.
Diverging from the instructions, I glued the track and wheel assemblies into one, so I could remove them for painting.
The MG with it's remote control mount. Following the directions the gun should be mounted within the frame, but I've attached one part of it with double sided tape for now so that I can open it up and insert the gun after painting.
Some kind of sighting system.
The main hull. Very dull, with only the drivers hatch breaking it up. There are also clear lights front and rear, some of which I lost :rolling: that have to be fitted before the hull goes together. The side armour is only resting in place until the tracks are painted and fitted.
And the turret mocked up. The sticky out bits are removable for now, and it needs a bit of clean up on the seams, but that's the whole thing pretty much ready for some primer & paint.
