Panzer III conversion to a Soviet SU-76i
    Hi this will be my next conversion if you can put up with another one.
    As you can see I've already started this.
    Parts.
    [ATTACH=CONFIG]n[/ATTACH]
    Parts marked are to be removed.
    This is were the f/r shock absorbers and centre hatch will go.
    Making inner missing wheels and rear idle wheels, trying to get some front sprockets and will be
    fitting 1/35 track hopefully.
    Totally removed all the hull details, added brass grills.
    Totally remade rear panel, made exhausts and towing ponits.
    Fitted gun emplacement, main gun and shield.
    Will be using the old turret hatches on the rear engine deck (before & after).
    Thank you for looking in.
    Pete.
    • 22770
    Some very nice work already Pete.
    • outrunner
      • Apr 2019
      • 2420
      You really know your way around that stuff, great job there.
      Andy.
      • scottie3158
        • 14201
        • Holbeach
        Pete,
        Lovely work.
          Cheers Ian, slow going in this heat the glues drying before I get the part in possession:rolling:.
          Pete.
            Andy.
            Cheers Andy I won't say that more luck than anything else.
            Pete.
              Pete,
              Lovely work.
              Cheers Paul much appreciated.
              Pete.
                • 18901
                Looking good so far Pete. First rate scratchery as always.
                  Thank you Tim getting there slowly, but it would help if I knew what I was doing it started off as ME109 :surprised::surprised::surprised:.
                  Pete.
                    Small up date.
                    Replaced the toon barrel.
                    Made f/r shock absorbers and hatch in the lower hull.
                    Fitted rear fuel drums adding some missing details.
                    Fitted 2x side stowage boxes, fire extinguisher, spare track to front .
                    Added 1or rivets/bolt heads here and there.
                    Just the lights and wiring, tools and couple of handles and wait the front sprockets to come to finish
                    off the suspension/ wheels work.
                    Thank you for looking in, hope you like it.
                    Pete.
                      • 15681
                      Hi Pete
                      Excellent. Must be hard doing a Toon conversion. Scratched parts have to be in "Toon Style" but you have a huge amount of Toon experience so maybe you brain is turning "Toony" :tongue-out3:
                        Another one to watch. Looking brill so far Pete.
                          Hi build stage complete had to re work all of the running gear as you can see, new f/ sprockets, R/ idlers and axel, make inner road and top return rollers.
                          Added some jerry cans and stowage for a bit of interest.
                          [ATTACH]391757[/ATTACH]
                          [ATTACH]391758[/ATTACH]
                          [ATTACH]391759[/ATTACH]
                          [ATTACH]391760[/ATTACH]
                          [ATTACH]391761[/ATTACH]
                          [ATTACH]391762[/ATTACH]
                          Pete.
                          • JR
                            • May 2015
                            • 18273
                            Doesn't get much better Pete:thumb2::thumb2::thumb2::thumb2::thumb2:
                              Hi John I hope I can I'm lean such a lot of new things on the Toon group :smiling::smiling::smiling: plus I'm now getting freebees from the kit builders more on that later .
                              Pete.
