Totally missed this one Mr T. Had a very enjoyable read through. These old Tammy kits are ideal for kitbashing. Liking what you have done so far. Keep it comin my friend
SimonT - 1/35 Tamiya Sdkfz.223
Jakko/John - I suspected that Tim had something more fiendish in mind....
....and indeed he did....
Tim - didn't even know what a solder pot was. I had to look that up. I do own a desoldering suction tool though. Bit more trouble, and cost than I want to go to though thanks. Think I will stick with using the round nose pliers considering how infrequently I need to bend tubing
Steve - it's been festering away in the background. All the parts clean up was done off site in between work on other things. I do like the 222/223 even though the Tamiya kit is rather outdated straight out the box. Hopefully it will be passable in the end
I really should get one of the Hobbyboss versions done - should be much better
Graeme - thanks. Herman must have ticked the stainless sports exhaust option :smiling3: At least they are the right shape now
John - morning. Update waiting for you below:
both rear mudguard boxes added c/w their etch details - numberplate back board, piano hinge on the side and the two part latch
the chassis armour plate added at the front - this was sanded down to a better thickness
turret mesh hatches added
I went with the Eduard mesh and kit frames then sanded down the frames to half thickness
The kit is the new release and comes with a set of steel mesh - no mention of it at all in the instructions - but I preferred the Eduard meshComment
Coming on nicely Simon. I never had an electric solder pot, by the way, I just used to use a stainless steel spoon placed on the Aga hot plate.....the hard bit was the desoldering pump. 145 solder works best.......Comment
added the door mounted storage boxes and etch mods
found that Eduard have transposed the numbers for the piano hinges on these boxes and the ones on the rear mudguards
as a result I had to trim down the ones for these door boxes as I had already used the shorter ones on the rear boxes
luckily the hinges on the rear boxes can not really be seen
also added the bracket on the side of the large bin and what appears to be a bump stop to prevent the door smashing the lower bin
I also washed the turret in my mug of tea :smiling4:Comment
John - it could be a new trend. Dark builders brew for a dark wash, wishy washy vending machine brew for a light wash etc etc
Karl - ok until you knock the bottle over :thinking:
Rick - drop. Turret in place, turned model over forgetting that small detail. Off it went with a bounce off the knee and a graceful backflip straight into the best Yorkshire brew
Si - Nuts and Bolts Vol4 and Ryton Panzerspahwagen and also the Toadman 222 photo cd for some common detailsComment
