Hi this will be my next attempt at one of these little guys.
The Char B1 French version I might be adding one or two auditions !
[ATTACH]392843[/ATTACH]
The French version you have to do this.
-Add second transmission tube under the 75mm gun.
-Add LOT of rivets and bolts and drill missing holes.
-Build the antenna track between hull and antenna port and wire.
-The mud evacuation port must be cut out on the front sides and add mud shoots, they are solid on the kit.
-Add missing tow eye in front of the transmission tubes.
- Added exhaust shield clamps
- Rebuilt radio antenna,
[ATTACH]392844[/ATTACH]
[ATTACH]392845[/ATTACH]
[ATTACH]392846[/ATTACH]
[ATTACH]392847[/ATTACH]
[ATTACH]392848[/ATTACH]
[ATTACH]392849[/ATTACH]
Got as far as I can waiting for a new bunch and die set to arrive so I can finish off the detailing.
Hope you like it.
Pete.
- Make an access door on right side cover up engine grill.
- No tracks on front, no tools on fenders, no jerrycans.
- Fit lift hooks on turret cupola.
Hope you like it.
Pete.
