T80 something and BTR70 something
  • David Lovell
    • 2186
    I built the BTR a few days back but decided airbrush and these temperatures probably aren't beneficial so dragged the T80 out of the stash ,won't take the link and length any further as covered by the fenders ,not a bad little kit but a fair bit of square peg round hole fiddling, vague instructions , have knocked off as mutch etch as I've glued on ,came with turned brass barrel but the detail was better on the plastic one especially the thermal jacket?
    Baring in mind the kit is 1/72 there are SIXTY FIVE pieces including the etch just in the turret
    Will finish up and show them some paint when conditions improve. Dave.
  • SimonT
    • 2824
    Which kits Dave?
    • David Lovell
      • 2186
      Hi Simon the BTR is Trumpeter very simplified only a couple of small sprues, I've got a BTR80 by Ace arrived today most of the reviews say its for the brave only but were see. The T80 is model collect a slight stinker for them ive always found their stuff ok ,will man up and do them both tri tonal need to get away from mono tone but in my own humble opinion mono tone is much harder especially in 1/72 if not careful you end up with a coloured lump im sure you know what I'm trying to say. Dave
      • SimonT
        • 2824
        Thought the BTR looked Trumpeter like - I have a couple in the stash
        Also have an ACE - can’t remember if it is an 80 or a 70. It is in white on the box top. Not dared open that one yet having done an ACE kit before
        Have a few Model Collects - they look good, not built any
        Shall look forward to seeing these progress :thumb2:
        • David Lovell
          • 2186
          Originally posted by SimonT
          Which kits Dave?
          Ace kits are usually not that bad accept it for what it is and go with the flow plus their limited run ,but as ive said with the Eastern block stuff it might not be all that but your subject matter is endless. Dave
          • SimonT
            • 2824
            I've only built one ACE Dave, the T62 but I ended up replacing a lot of the kit as it wasn't very good - sort of put me off a bit even though they do a great range of subjects
            Your T80 looks to be better moulded
            • Steve Jones
              • 6615
              That's a terrific build Dave. Nice to see. Looks a half decent kit. Like the additions you have made. Hopefully the heatwave will stop soon so you can get some paint on her.
              • JR
                • May 2015
                • 18273
                Nice Dave, I build the ACE MG bunker , every one called it the Dustbin ! :smiling3: Not too bad, bit small in scale for me at 1/72
                • BattleshipBob
                  • 6792
                  • Bob
                  • Cardiff
                  Lovely work Dave but toooo small for my peepers!
                  • Si Benson
                    • 3572
                    Hi Dave,
                    Good to see your keeping busy With some Braille scale builds :thumb2:
                    Think I built that model collect T80 and found the same with it being a bit of head scratcher with some of the bits!
                    off to take a look at that Ace Btr80 you mentioned :smiling4:
                    • tr1ckey66
                      • Mar 2009
                      • 3592
                      A couple of nice looking kits Dave. Looking forward to seeing the progress.
                      cheers
                      paul
                      • David Lovell
                        • 2186
                        Originally posted by Si Benson
                        Hi Dave,
                        Give us a bit Si ill post a pic of box top
                        • David Lovell
                          • 2186
                          This is the kit as you can see seems a nice fret of etch and a high parts count Dave. Click image for larger version
                          • Si Benson
                            • 3572
                            Cheers Dave :thumb2:
                            I had a look at all the Ace BTR family over on Scalemates and see they have a couple of new releases out soon :smiling4:
                            • David Lovell
                              • 2186
                              Si i also use a site called Henkofholland click on plastic manufacturers choose your brand and most models are shown ,parts photos built kits plus links to sites like on the way diffrent IMPS sites all giving build reviews, plus loads on there resin kits, figure manufacturers and it only covers 1/72 its my go to. Dave
