Hull sprayed with basecoat - The AK3 Russian Green sprays well, diluted about 50/50 with tap water...............
Started on the figures - standing figure is the tank commander ( Zvezda ) the other four are the ICM figures. These were part of a T-34/76 boxing. The /85 turret is larger, and I may have difficulty in fitting all four, so one may be consigned to the reserve bench
The only clean up done so far is the joint faces - the moulding seams will be cleaned up next - I find it easier when I have something larger to hold onto.......
Turret finished, primed & basecoated - I've left off the vision prisms in the commanders cupola - when I fit the figure, they won't be seen .
Figures assembled sans heads & headgear, 4 primed Russian Uniform Khaki, the tanky black.................
Next up a bit of detail painting on these figures - I'll have to break out the tiny brushes & magnifier.
Although I'm normally a 1/72 man I've had a look on Amazon and I can pick one up for £19. On the one hand I'm very tempted but on the other hand I know the reaction I might get.........
Keep up the good work.
Andrew,
go on, you only live once....................
I knew I had an AM decal sheet, but couldn't put my hand on it.................... I moved a shhet of emery paper & found it! Microscale 1/35 13-7 Soviet Armor Markings
Not sure about the Soviet Navy flags, or the parade stars, but I'm sure that one of the patriotic slogans will be used ( luckily there is a translation of them! )
