Andrew,
oddly enough, I have a ICM late T-34/76, and a AFV Club early T-34/76 in the stash, but at the moment only one set of tracks ( ignoring the nasty vinyl bits supplied ). I am in the process of getting some new ones, but they seem to be coming from Siberia by mule-cart!
After a really lazy weekend, I've added the details & decals to the T-34 ( Death To Fascism)- this is now pristine, so now, I'm going to start the process of dirtying it up.............................
There is a large box, with a pipe out the side, which Zvezda direct you to fit on the rear plate, between the exhaust pipes:
I've looked at a fair few pictures of the T-34/85, enough to say that this wasn't a common fitting, so, I'm going to leave it off! Anyone know what it is? Smokescreen generator? Improvised oven?...........................
Jakko,
the two small drums are oil drums, as opposed to the 3 diesel drums. That box really baffles me - It must be a field modification, not official, as it would prevent the service hatch to the transmission from being opened.............
[ATTACH]399077[/ATTACH]
I'm sure I've read somewhere that it's an 'oven' of some sort..
I'd have thought the crew would have enough to deal with fighting German forces let alone knocking up a few loaves of Mother Russia's finest granary..
I thought they used one of the three drums for oil, the other two being for diesel. But it’s proving frustratingly hard to come up with a source for any of this. Maybe I should stop asking Google and try looking in books instead …
I've just flipped through the Zaloga 'T-34 In Action', and I can't find one picture with the box!
However from Henk of Holland website:
" This vehicle is a PostWar T34/85 from East Germany. On the back of the vehicle is an oven for pre-heating the engine. The T34 is a post war and Polish made. The East German army adapted on some T-34's this oven. The oven was used with coal and wood. "
Well, that's some info, but was it relevant to WWII? I'm certainly leaving it off!
[ATTACH=CONFIG]n1133593[/ATTACH]
Good call Dave, I'll remember that when I start throwing glue at mine.. :thumb2:
The Zvezda model comes in the usual box-in-a-box, to resist transit damage. Sprue shots & a few detail shots.
[ATTACH=CONFIG]n1132907[/ATTACH][ATTACH=CONFIG]n1132906[/ATTACH][ATTACH=CONFIG]n1132905[/ATTACH][ATTACH=CONFIG]n1132903[/ATTACH][ATTACH=CONFIG]n1132904[/ATTACH]
It's a simple model, but then again the externals of the T-34 were simple
[ATTACH=CONFIG]n1132910[/ATTACH]
Casting texture on the turret sides
[ATTACH=CONFIG]n1132908[/ATTACH]
Road wheels - hubs OK, the rubber tyres will need a bit of beating up.......................
[ATTACH=CONFIG]n1132909[/ATTACH]
Tracks, link & length - the sprues join together to make a track jig for the top run..............
[ATTACH=CONFIG]n1132911[/ATTACH]
Why don't more companies do stuff like this? That's a great use of outside-of-the-box thinking!
If I hadn't tracked that box down, it would have niggled me - like a stone in your shoe.......................
I have been working on the T-34, sealed all with a coat of gloss varnish, then started on washes to wheels & hull - nothing worth taking a piccy of, though!
