KV 1s Ekranami Toon
    KV 1s Ekranami Toon
    KV 1
    WIP
    Added missing holes in road wheels added detail to socket and idler wheels, addad 1/35 scale track, removed all detail on the rear engine deck and remade it, made some PE grills.
    Before and after.
    [ATTACH=CONFIG]n[/ATTACH]
    Before and after.
    Before and after.
    Before and after.
    [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
    Thank you for looking in hope you like it.
    Pete.
    • 18901
    Nice job Pete. You get in more modelling per square inch on these than most people do per square foot on an out of the box build....
    Is the turret scratch built or a resin aftermarket part?
      Thank you Tim, I wish I was that good , no it's a resin aftermarket part from RetorKit by Dominique Jadoul and he is now using five of my builds on his web site as marketing sales photos , in return I have had some free part and kits :smiling::smiling::smiling:.
      Pete.
        Build stage complete.
        Hi have added bolt on applique armour to the turret also made two grab handles and added a bit more detail to the hatch, add thicker armour plate to hull sides and front.
        Added mesh and made heat deflector flap to the engine rear panel, made up return flanges on the track guard hangers.
        Made up front mounted antenna mast, added light and wiring.
        Thank you for looking in I hope you like it.
        Pete.
        • outrunner
          • Apr 2019
          • 2420
          Nice one Pete, you must have a Toon production line going there.
          Andy.
            • 22770
            Cracking work Pete
            • adt70hk
              • Sep 2019
              • 10406
              Quite simply brilliant. Very well done yet again .
                • 18901
                Super work as always
                • JR
                  • May 2015
                  • 18273
                  Pete good to see you have had recognition from RetorKit by Dominique Jadoul. Having good exposure has paid dividends, and you deserve it .
                    More brilliant modelling Pete :smiling3:.
                      Andy.
                      Cheers Andy yes I'm in the groove at the minute so so might have to paint one or two soon though :smiling5: .
                      Pete.
                        Originally posted by papa 695
                        Cracking work Pete
                        Nice of you to say so Ian thank you.
                        Pete.
                          Thank you Andrew simple yes, needs a lot of work on the brilliant.
                          Pete.
                            Much appreciated Tim thank you.
                            Pete.
                              Cheers John it's been a long road but slowly getting there. Thank you for your support along the way.
                              Pete.
